More complex clamping on the French Footed chest
Bill Tindall
If I have a weakness for buying woodworking stuff it is clamps and I have a colorful eclectic collection. The ones I use the least are the Besseys. They are too heavy/clumsy and pricey to boot.
What is under this mass of clamps is the facing for the cabinet. The French Feet are applied which requires the whole of the cabinet to be faced. The facing covers up the dovetails which is an added benefit to the looks. Note the facing is plain as dirt so the intersections look good.
Rather than butt joints for the vertical sections I used "darts", something I saw on a piece in Winterthur. The male part can be precisely fitted with a shooting board and hand plane to the female part which is sawed and chiseled with the aid of a notch template. It is really an easy joint to execute.
All that remains for the case is to fit the carved skirt, when it gets carved. Then it is on the the bow front drawers, something I have not made before. Any suggestions?
Re: More complex clamping on the French Footed chest
Lovely, and thanks for showing your work in progress on this piece.
Jim Hoeller
For the bow front drawers, I would recommend laminate construction. Use stacked and glued MDF for the forms and make sure that the face of the form(s) is/are dead square to the base. Also, use cauls and lots of clamps.
FredD
You have started with solid wood inside and out , why degrade the drawer fronts ? Keep them solid in my opinion.
Good pics , keep them coming.
FredD
Bill Tindall
I intend to do them in a traditional way which is to lay up "brickwork" and veneer over it. I am not finding instructions on laying up the brickwork part. We have two people from the Mack Headley and Sons shop coming in next week for a club program so I hope to get some help if they have some spare time.
Jesse Cloud
Steve Latta wrote up a good description of how to make a bricklaid piece (an apron in this case) in his article on Building a Federal Card Table in FWW issue #180 (November, 2005).
If you don't have access to the issue, the bottom line is to divide the piece into four layers. Treat the 1st & 3rd layers the same, and 2 & 4 the same, hence brickwork. Miter pieces together so that they will form an arc containing your desired shape, e.g., that you can bandsaw the shape out of. Have one set on lengths and angles for set 1&3, and a different set for 2&4. Glue, bandsaw, and fair. Its much easier to visualize if you can see the illustration in the article...
thanks I will borrow that issue
Bill Tindall
proceeding with this sugggestion
Bill Tindall
The arc of the drawers is such that the cross grain reinforcement of real "brick work" will be unnecessary. Looks like I can efficiently cut the pieces from 8/4 stock and pattern route as the article describes. I will vacuum glue the veneer- more assured of success.
