Adjusting the Delta 22-580
Terry Alexander
I love my 22-580 planer. I have run I don't know how many bf through this planer...always with excellent results.
However, lately I noticed that the planer if "off" .020 from the left side of the planer to the right side of the planer. I checked my manual and the only "relevant" info I can find to cure this is the section for "Adjusting The Height Of The Outfeed Roller". Is the where I should be looking to bring my planer back in line?
As always.....TIA
Terry Alexander in West Texas
Re: Adjusting the Delta 22-580
Just changed blades on mine today
David Yoho
Terry, I don't know about the adjustment you're asking about but it brings to mind another thought. Not knowing what alerted you to this discrepancy, could it be something as simple as your blades are worn a little on one end and need changing?
Just this morning I pulled out my manual and went about flipping the blades on mine. I'd been using them on the original side since I purchased it and I knew it was time to get a fresh edge in there. To my surprise, changing or flipping the blades on this model is so easy it's a piece of cake. The edge of both blades showed several nicks and wear, although they still cut pretty good. It takes only about 20 minutes or less and there's no adjustment needed. Delta did good on this one!
I've changed the blades...and...
Terry Alexander
...you're right. Delta did a bang up job on that.
What "tipped me off" is that I have some 45� mitres that were not fitting flush. Took calipers and AH HA...found the problem.
Started planing "junk" wood to test my theory and that proved it.
T
Re: I've changed the blades...and...
Keith Newton----Little Rock, Arkansas
Make sure there are not any chips under that bed plate holding it a bit higher on one side.
Otherwise, I think I would look under the bottom, where the gears cross over and turn the screws.
Find the number of threads per inch, then divide by the number of teeth per gear, will reveal how many teeth to rotate.
I don't have my manual, so I am just guessing by a quick glance under the tool just now.
Otherwise, call Delta.
