Request for Finishing Advice - Long
Bartstar
Hi Fellow WCers,
I am nearing the completion of the Synth cases I have been building for my BIL's Moog Synthesizer project.
Cases are made from Baltic Birch Plywood and will have hardwood added to the front faces for wear and for decorative advantages.
BIL wants to paint the cases black, as this is somewhat traditional for studio equipment and then apply a high gloss finish to them ALA piano finish. BIL has suggested using Rust-O-leum paint (In quart container, not spray kind), most typically used for Metal, to paint the cases. Not sure I think this the best way to go. Was thinking of using a foam rubber roller for a very smooth, no brush stroke, appearance. We do NOT want to highlight any wood grain.
I do not have spray equipment, so am looking for advice on hand applied finish methods to achieve this goal.
I was thinking that I would use Zinnzer Seal Coat as a primer to seal the wood before painting black. Although, I would assume that if I used an oil based paint, I may not have to use Seal Coat at all.
Not sure of the best Gloss Poly products to use. Water based would be nice since I will be doing this inside and would like keep the odor down. In any case, the finish coat needs to be very durable as these cases will be subject to moving and getting knocked around.
Any advice is most appreciated.
Thanks
Bart
Re: Request for Finishing Advice - Long
Lee Grindinger
Some ideas and comments
Lee Grindinger
You're asking a lot of water based finishes.
First, I'd seal the wood with a good sanding sealer after sanding very smooth, than sand it lightly again.
The best gloss finish you can get is going to be an oil based enamel. Pigment makes a finish stronger so enamel paint is stronger than clear finish. Oil based finishes level better than water based finishes, it's about surface tension and water has much higher surface tension that oil.
Without spay I'd suggest the sanding sealer followed by a few coats of oil based enamel sanded lightly between coats to remove nibs and brush marks.
Perhaps a clear final coat from a spray can would help if you can't get a good top coat from the paint but this will not add strength, just looks.
Nat Robison
It seems like most of the instrument cases you see are finished in flat black but if he wants gloss, so be it. I've found the best finish from a roller to be the "velour" rollers available at Lowes, HD, etc. They have a very short nap. If you combine that with an oil finish that will level out somewhat, it may be the best you can hope for. I would echo the other thought that a few coats of oil paint would be as good as top-coating with WB poly.
Clint Searl
Easy
Clint Searl
Base coat with flat interior latex using a short nap or sponge roller. Three or four coats. Top with clear gloss water borne poly. Three or four coats. Rub it out with auto rubbing and polishing compounds for higher gloss.
Clint
paul in AZ
Several houses ago I had to refinish my front door. I used Rustoleum high gloss metal paint from a quart can and on a whim did it in Chinese red. With sanding/sanding sealer/sanding again I brushed it on and got a really nice finish with one coat. That paint is tough and looked great for years.
I'd wonder about a glossy finish for audio equipment. Any I've ever seen has a matte surface.
AZ in Colorado Springs
Airplanes (and probably other machinery) are painted with two part epoxy paint. When I was in the maintenance squadron in the Air Force, we used the same paint on the shop floors. It was very durable. Typically it is sprayed, but it was rolled onto the floor, so it doesn't have to be sprayed.
I'd suggest stopping by an auto body shop to explore that if it strikes you as a good option. The techs there might be able to advise on prepping the wood. You might even get them to spray your boxes when they're using the same color on a car.
Construction Problem
Howard Acheson
If you are planning to glue or otherwise firmly attach solid wood to the Baltic Birch, you are headed for a problem. The solid wood will want to expand/contract with changes in relative humidity. The Baltic Birch will not move with these changes. This will cause the glued up panel to warp or otherwise deform possibly leading to cracking or joint failure. If you want a solid wood look to the front, you should use a veneer that does not exceed 1/8" thick. Another option is to just use hardwood only for the front panels but you still need to allow for the expansion/contraction of the solid wood panel. It will have to sort of "float" in dados which might lead to vibration and noise.
Best choice is to laminate a veneer onto the Baltic Birch panel.
As to your finishing plans. Last year I was building some painted built-in drawers for a children's room. The drawer fronts were solid poplar. I sanded them smooth and applied a coat of dewaxed shellac. I then sanded the surface with 320 paper. I then brushed on two coats of a Rustoleum oil based enamel. The paint came out without brush marks.
Be sure to test out your finishing plans on scrap material. Never let your project be your learning curve for finishing.
Re: Construction Problem
Bartstar
Hi Howard,
Thanks for your post. I am a bit surprised by your comments, however. Cabinet makers have been attaching solid wood rails and stiles to the front of plywood cabinets since the introduction of Plywood. Why would you suggest that there is an issue with doing so now?
Thanks
Bart
FredD
Have yo agree with Howard , Bart, if I understand your project and it sounds like a box constructed from Baltic Birch , then a solid wood panel would have problems down the line when the seasons change.
That is not the situation with face frame attachment to plywood cases mostly because none of the members of the face frame have any significant change due to their small width.
I think the suggested Veneer presents the easiest, problem free approach.
FredD
Re: Construction Problem *LINK*
Bartstar
I think your all missing the idea - there is no hard wood panel in my project. These are just cabinets to which I will be applying hardwood face frames - very typical cabinet construction.
My BIL has been posting a detailed description of the project with pictures if your interested.
Regards
Bart
Synth Case Description
Clint Searl
Here's an example...
Clint Searl
of the latex base coat - clear coat schedule on baltic birch. This one happens to be topped with a rubbed effect lacquer, but brushed-on water borne poly will also work.
Clint
FredD
Well no problem then Bart. you didn't mention face frame, your right , should be no wood expansion issues.
FredD
