Wood Vaporizer questions- long *LINK*
Galen Vetterick
I'm going to build the wood vaporizer per the link instructions but wonder about several items. Hope someone can answer.
Is the heavier 12-2 wire really needed for the burner leads?
The number listed for 12-2 speaker wire from Radio Shack is actually single 12 hook up wire so not valid and I would need to find other source.
The article and link to article says you can use the chargers existing 12 volt wire leads by cutting off clips. This wire is only 16 ga so will it get hot and unsafe or not?
The 1/4" mono phone jack and socket would not seem to work as shown for two wire. Am I wrong? The socket red lead shown would short out to the metal charger housing as that tab is common to the metal panel mounting.
You would have to use only the tip connection and use two phone jacks?
The photo of the phone jack is a closed circuit and you don't seem to need the closed circuit. Even that unit the one connection is common panel ground.
In the Phil Roybal linked to article he used only the 2 amp setting on the transformer tap so do you really need the 10 amp tap setting?
Thanks if you can answer some items.
http://www.svwoodturners.org/TipsTricks/PriddleStyleWoodVaporizer/PriddleStyleWoodVaporizer.html
Re: Wood Vaporizer questions- long *LINK*
Bill Tindall
I'll bet this request gets some response form the electrical experts! I would want something in the output of this arrangement fused.
I don't have any expertise to lend to this request but I do have a question. What benefit does this arrangement provide over a typical wood burning device? Is DC required and if not is there a better way to safely provide a moderate low voltage AC current?
Bill
Galen Vetterick
The charger still has a thermal protection on the output just not sure how well it will work for modified application since I found no data.
Cheaper to just try without a lot of investment. Had electrical parts and charger on sale and can always revert it back to replace my 6 amp old charger.
I have seem articles on AC unit as well and actually have surplus 120/12 Volt 6 amp transformer that I could try that too. Just seemed to have more info on the DC conversion.
I can see vaporizing purchased tips so will work with home made.
I enjoy making home made anything. Yah, I'm cheap!
Carol Reed, Strawberry, AZ
You might post this on the turning side. There are many wood burners there.
FWIW, I built a wood vaporizer last spring for Molly Winton. So far as I know, it is working. Also she has a nifty little booklet showing how to make pens and dealing with the heat issue.
Now I need to make one for myself! Thanks for the nudge. I am going to HD today. I will pick up the dimmer switch. I have everything else.
Carol
Galen Vetterick
Watch Molly demo in Albuquerque last year. Not a burned finger could be seen!
Thought maybe I had her booklet but no luck. Not even a reference in her web site.
I see Pakard Woodworking has Winton kits that I can get wire and her info on shaping pattern tips.
Did you use heavier 12 ga wire to pen on Molly's?
Did you use some type of jack and plug to connect pen?
Do you know if both 2 amp and 10 amp switch settings are used at times?
Thanks for info and I will try to copy over to tuners side.
Re: Carol
Did you use heavier 12 ga wire to pen on Molly's?""
I didn't do the pens or teh wire to them.
I provided 1/4" phono plugs and jacks.
Don't have a clue. Phil Roybal seemed to set his at 2 amps and as far as I can tell, left it there. Email him and ask.
Re: Carol
Galen Vetterick
Carol
Been looking at more designs. One even made from computer power supply by searching here. I threw away so many of those!
Think I know where I will go with this for now.
Thanks again.
charlie belden
"The number listed for 12-2 speaker wire from Radio Shack is actually single 12 hook up wire so not valid and I would need to find other source."
Either RS has changed their part numbers or My Bad. Let's start with the wire gauge requirement. Direct current (DC) requires larger gauge wires than the alternating current (AC) we have in our homes for the same safe current carrying capacity- which is just one of the reasons AC won over DC for electrifying out country. Look at the 12 V DC table on the following web page
http://www.windsun.com/Hardware/Wire_Table.htm
If you want to pull 10 amps through a cable - that's only 8.5' long - and that's Down and Back so 4.25' from charger to pen - the table shows that you need 14 gauge wire. If you want to work up to 6' from the DC source (the charger) - you need to go up to 12 gauge wire.
If you stay at or below 2 amps you can use 16 gauge or maybe even 18 gauge if you pay attention and stop if the wiring feels warm..
You want multi-strand cables not solid wire cables because they're flexible so maneuvering the pen is easier. It's also preferable that the two wires stay together and move as one unit rather than two separate wires. You CAN tape two wires together - but the result won't be very flexible. ZipTies are preferable if you have to go with two separate wires.
"The article and link to article says you can use the chargers existing 12 volt wire leads by cutting off clips. This wire is only 16 ga so will it get hot and unsafe or not?"
If you're going to stay with only 2 amps, which should be more than adequate for vaporizing wood - IF - the "burn wire" isn't too large - 16 gauge is safe to use.
"The 1/4" mono phone jack and socket would not seem to work as shown for two wire. Am I wrong? The socket red lead shown would short out to the metal charger housing as that tab is common to the metal panel mounting."
The part that passes through the metal cabinet is insulated so there can't be a short between the two sides of the electrical circuit.
"You would have to use only the tip connection and use two phone jacks?"
You need TWO legs for a circuit - a path from the positive side of the source to the load and another from the load back to the negative side of the source
"The photo of the phone jack is a closed circuit and you don't seem to need the closed circuit. Even that unit the one connection is common panel ground."
The tip of the phone plug has an insulator between it and the metal sleeve around it so no current can flow between them. In the plug, the positive and negative are also kept apart by insulation.
"In the Phil Roybal linked to article he used only the 2 amp setting on the transformer tap so do you really need the 10 amp tap setting?"
Just because most battery chargers go up to 10 amps doesn't mean you HAVE to use all 10 amps. But it's prudent to Plan For The Worst. If 2 amps does what you want to do - then you don't need more than that. But if it doesn't have the ability to use more amps gives you room to get to where you want to go.
"Thanks if you can answer some items."
No problem. There's a link at the bottom of the page you provided to e-mail the webmaster - me - if you have more questions.
Thanks Charlie
Galen Vetterick
I see the table says it has allowed for out and back so #14 is good for 10 amp at 8.5 feet one way with the noted drop.
I'll probably use 14 gauge and maybe 6.5 feet one way so if I set on 10 amp I'd be OK. Still have a 14 ga. ungrounded extension cord to rob from. Not use the 16 ga. from charger.
Interesting to know that two 10 amp chargers I have only have 16 ga wire and about 6.5 feet one way for 12 volt leads. Must be how I got cheap chargers.
I have two 1/4" mono phone jacks and on both the plug post tabs are common to the mounting and NOT insulated to the box if it were metal.
Confirmed with ohm meter. That would ground one lead and not work.
I will check Radio Shack today and see if there is an isolated (insulated) version so it would not ground to the metal charger housing. That way I can use one jack for both leads.
I've read some details to bypass the thermal overload and others say to leave in on the 12 volt side. Guess I can leave in and see if it drops out the burner too often.
Thanks again.
Steven Antonucci
My two cents...
steven antonucci
I helped Charlie with a lot of the content of the article after talking to Graeme. He's the man with the plan, but for insurance reasons, won't put his name on it.
I didn't want to cut open my charger, so I used the speaker cable for one simple reason- it is flexible. The 12-2 I had was so stiff I was constantly tugging at it. If you want to lose the battery charging capabilities, you can cut the alligator clips off and just use that wire (what GP's unit looks like).
I never run the think more than 8-9 amps, since it tends to overburn the surface. 5-6 amps is much more controllable, but 8-9 gives better heat recovery. The lower the amps, you may have to pause in between burns, but you get cleaner lines... I think this is the major advantage over commercial units...more power!
Disclaimer: I have a degree in Electrical Engineering, but I was at the bottom of my class... use this at your own discretion.
Steve
Steve  ---Good for at least a quarters worth!
Galen Vetterick
I was wondering how the dimmer works on the circuit. I assume they have a triac and never seen that used on a power feed to a transformer. Think the light dimmer I have says not to use on a motor or transformer. Thought maybe I should buy a new control and get one designed for a ceiling fan. May trigger the triac better?? Guess I need to take one apart and learn.
No electrical engineer but made up my own circuits and project YEARS ago going from tubes to transitors and then into ICs. Etched my own circuit boards. Forgot what I learned studying for structural and mechanical engineering. Retired so forgetting that too!
I had better get back to turning or the piece on the lathe will change shape again.
Thanks again
