Motor Capacitor Question
Ralph Lipeles
I'm restoring a vintage Shopsmith Mark V 500. The motor just hums, but when the belt is removed, it starts and runs. So I assume that the starting capacitor is not good. The one that is there does not appear to be original so I do not know if the capacitance, 161-180 mfd, is correct for the motor. Is exact capacitance critical? I'm not sure what to do and appreciate any help that I can get.
Thanks in advance,
Ralph Lipeles
Re: Motor Capacitor Question
Joseph Mulherin, Sr
Ralph, go to the Yahoo SSUSERS website and ask the fellas there ...they have all the proper answer for anything to do with the SS.
Bill Turpin in WNC mountains
You can change the cap by up to 10%, but only in the UP (higher value) direction. Higher value caps get physically bigger, this will limit the error factor. You could also have burnt, dirty, or open centrifugal switch contacts. They are usually in the rear of the motor and should be closed when motor is not on. Blow out the end bell, sawdust could be keeping them open. Contact points can be LIGHTLY sanded or filed after removing the end bell. Before disassembly, scratch line-up reference marks in both end bells and the motor body. Inspect the cap for loss of salt solution. There is a brown plug between the terminals. Be sure that it is not swelled, broken, cracked, or missing. There should NOT be any salt crystals visible. I recommend that you attempt to obtain motor specs to check for proper size.
del schisler
here is a phone number Technical Services Hotline, TOLL-FREE at 1-800-762-7555 for assistance.
