Buying a ladder Question....
I working on a house that is one story in the front and two in the back and on a level lot. I need an extension ladder. Trying to decide what length to buy. Stuck between a 28' and 32". (25' and 29' working lengths respectively.) Of course, that the length of the ladder, not it's height once eland on the wall. The Pros for the 28" are its lighter by 13 lbs, easier to handle, easier to haul and 10% cheaper. But is it big enough?
I'm looking for feed back. Any advice would be appreciated.
Re: Buying a ladder Question....
Mark Nowicki
Hello Barry:
You are a building inspector and you don't have any ladders, or ladder buying or climbing experience?
We should be asking you.
Mark
We Have A Resident Expert...
David Yoho
I'd wait to see what Ellis says in regards to your question. If anyone here knows about buying a ladder, it's him. :D
P.S. - Sorry, Ellis, couldn't help it!
P.S.S. - Carol, sorry to beat you to it!!
Jason Roehl in Lafayette, IN
My vote would be 28'
That's the longest I own, and it has served me well for a dozen years or so. I have not met a second story I couldn't reach with it when they set on a level lot--this includes older houses with two 10' stories. If that's what you get and find you need a little more reach, add a stabilizer--it will stand the ladder out from the wall about a foot and allow you to take a couple more steps up the ladder that would otherwise put you too close to the wall.
A 32' ladder definitely becomes much more difficult to handle. Even when it's not extended at all, the center of gravity is 8' off the ground, which most of us mere mortals cannot grab. I'm 6' tall and can touch 8', but can't grasp anything at that height. A 28' ladder's CoG is only 7' off the ground, so it's much easier to grab at or above that height to control the ladder.
Jason
P.S. Mark, I don't think I've ever seen a home inspector with more than about a 16' extension ladder--usually enough to get on the roof somewhere on a house.
Bill Howatt
The other factor is how comfortable are you going from ladder to roof and vice-versa. If you are like me, the extra length sticking above the roof makes me feel better since I can grab the ladder and more likely remain upright instead of bendng over to get back on it. Also, a longer ladder is not extended as far and is less "springy". OTOH, I agree with the increased difficulty in handling the longer, heavier ladder - I do have a 32' ladder.
Depending on the house, a long ladder can be limited for other work such as under the eaves because the sections are too long to be placed at the proper angle. Naturally, the longer the section, the more likely this is to happen but it isn't an issue if you also have a shorter ladder.
Bill
My old house had ~3 stories in the back (2 stories and a daylight basement). It had a shed dormer in the back, so I could easily clean that gutter - but there was no way I was going to go down the slope to clean the gutters on the sides of the house.
My vote is for a 32' ladder. You can set the base out further for more stability. It might weigh more, but the stability really helps.
Climbing onto/off a roof
Every ladder safety article I've ever read recommends three rungs or so above the roofline, to provide a place to grab when making the transition from ladder to roof or roof to ladder.
Regardless (a setup trick), and another comment
I can't remember where I read this or if I figured it out myself, but setting up a long ladder solo is made a little easier if you tie a rope to the bottom rung long enough to extend to where you're standing at the head of the ladder, and then walking along the rope as you tilt the ladder up. Long ladders have a tendency to come up off the ground as you tilt them up, because the center of gravity is higher than you are (unless you're Manute Bol); the rope helps to shift the center of gravity a little.
Better, and far safer, is to have an apprentice to foot the ladder, but that approach stopped being available for me after the boys moved out.
Incidentally, although they're bulky and a little awkward, one of the other advantages of the stabilizers is that they do, indeed, stabilize the ladder. I think there are two things in operation: one is that they create a wider contact patch at the wall; the other is that they have little rubber feet that are resistant to movement.
Of course, where you can tie off the ladder at the top, or screw blocks one to each side of the ladder where it touches the wall/eaves, you should - but the former is only occasionally possible, and the latter generally works only where you're setting up a ladder for a while during new construction/remodeling.
Re: Climbing onto/off a roof
Bill Howatt
A 3 rung minimum makes very good sense to me but I've seen people more confident and agile than I am bend over to grab the top of a ladder than isn't probably more than 1 rung or so above the eave - but I've also seen people walk unaided along the ridge of a 2 story house roof just after they've shovelled the snow off the roof!
Bill
Better too many than too few
Gravity's at work all the time. No desire to fall down the gravity well. When we get our house re-roofed, I expect to ask that an anchor be installed at the peak of the pyramidal roof for fall protection.
I do indeed have ladders. About six of them, just no extension ladder. I used to have two of them, but someone needed them worse than I did and stole them. That was a long time ago and I have not replaced them. Can't remember what they were. And, I am a little older now and things that used to be easy are not so much any more.
Been on many, many roofs.
And I never have more than about 1 rung above the drip edge. That 3-rung thing scares the heck out of me because I have to go AROUND the ladder to get on it, putting my center of gravity outside the edges of the ladder, and making it more likely that the ladder get pushed to the side during the maneuver. With just one rung above the drip edge, I can easily step over while grabbing the top of the ladder without shifting the ladder.
OSHA can kiss my ... uhhh...grits. ;^)
Jason
Sorry I missed this
Believe it or not, I've been up on ladders most of the day, working on the house. David couldn't resist mentioning a certain ladder-purchasing experience I had several years ago, when I presented my bride with a brand-spankin-new 24' Warner extension ladder as an anniversary present. Little did I know how hard she could hit, or how long she could go without speaking (to me at least). Our marriage survived, but I'm a lot more careful now about anniversary presents.
So that story isn't much help in answering your question, except for the fact that I bought a 24-footer and that has been plenty long enough for me to access my gutters and so forth that are two stories up. I would probably have gotten a longer ladder, except that weight started to become a factor, and my budget wouldn't cover a fiberglass ladder.
Whichever style or length you buy, I recommend getting a pair of adjustable-height feet. They cost about $60 for the pair at the borg, but once you get 'em, you'll never know how you lived without them. They can't be beat for use on uneven ground.
