Have a question? Ask Woody!
How important is leveling a bandsaw?
Roger Mallard
I'm about to put my bandsaw onto a mobile base for the first time.
Most mobile bases out there have leveling pads meant to steady the machine but not actually level the machine.
Have any of you experienced any negative effects like vibration from an unleveled bandsaw?
I could easily add real leveling feet to the base, but am wondering if it is actually worth it as long as the bandsaw is stable and reasonably level.
Re: How important is leveling a bandsaw?
George Colonel's Workshop-Havertown PA
Good Evening Roger,
I'll level with you! The bandsaw must be situated on a flat surface, so that each foot or pad/foot bears equally on the floor, and the saw can't rock back and forth as a chair with one short leg. Of course, it must be reasonable level and stable as it sits. If it vibrates when so situated, its not the fault of the floor, but the saw.
George
Won't effect the tool, but it may effect you. Band saws have a high center of gravity, the more you move that point off the design center line, the more unstable it will be. and you won't enjoy working on a saw that doesn't feel solid.
Every machine in my shop is on wheels, except the band saw. That's bolted to the floor.
Both of my bandsaws are on mobile bases.
I won't say either of them are truly level :) . But they are FIRMLY in contact with the floor. IMO, you need to be really stable. As an example, if I were to resaw a long heavy piece of wood, it wouldn't be nice to have the bandsaw shift. Also if I were to be cutting out a settee seat, it definitely wouldn't be nice to have my bandsaw shift.
My mobile bases are the sort which have the wheels in the "back" and the pads in the front and the little lever/wheel gizmo in the front also. I haven't really had any problems with them. The pads are all adjustable so that the saws can be "leveled".
On wheel's   Level   No problum
del schisler
Roger Mallard
Thanks for the honest replies gentlemen.
Based on them, I'll devise a way to level the base before I put the bandsaw on it.
