We value your privacy.
I am making a tiller for my sailboat. It will end up about 1 inch square and 36 inches long. Started off with some ash and walnut taking them down to about 1/8 inch thick and then make a bending form out of MDF. My question is what glue should I use and what finish I could put on it? Last year I made one out of oak and used polyethylene. This lasted about 6 months and the finish started to crack up on top.
I am not a big fan of using Ash in a glue-up for tillers. It is low on the decay resistance scale, and stains easily whenever you get a ding in the finish.
I would much rather stick with a solid wood, whenever possible.
If you feel like you need a bright finish, it is a lot cheaper to invest in a canvas cover to leave on it when you are not sailing.
Otherwise, I like just leaving the teak natural on my boats. A couple of time each year, they might start looking dingy, but spraying it with a 50% bleach / water will kill that. Then a very light sanding, will bring it back to life. Decay is not an issue.
Definately agree with using a cover on the tiller.
But solid wood just won't work for most tiller designs which have enough curve that solid wood means grain runout and a much weaker stick.
Even with a cover, Epifanes, or one of the other decent marine spar varnishes is a good idea. (By decent I mean Interlux Schooner, or Pettit Captain's. If you can buy it in a big box store it isn't a marine spar varnish no matter how nautical sounding the name.
Weldwood is a good marine glue and has the additional advantage of being dark and resistant to UV degradation. Epoxy will work if you add a dark filler, such as grphite.
Many coats of a marine spar varnish works well on tillers, buit expect to re-varnish every spring. Light sanding and a couple of coats should do it.
I'll not pretend to know anything about the forces on a tiller, so I can't tell you how strong/stiff/ dense/etc. your tiller should be, but if you're laminating it for a marine environment, I'd stick with a wood that is high on the "durability" scale (resistant to rotting in a moist or wet environment) such as teak, mahogany, black walnut, or locust. Teak and mahogany are the species I have seen used most often for boat work, but black walnut is surprisingly durable. I wouldn't use ash or other non-durable species if you can avoid it, because then you'll be relying on the finish to keep it from deteriorating.
For laminating, I suggest West System epoxy. I have used it for numerous driveway gates and other exterior structures and can recommend it highly. Technically, resourcinol glue, plastic resin glue, Titebond III or urethane glue are water-resistant for wet environments, though urethane glue isn't intended for continuous submersion.
Clear finishes on exterior woodwork will require maintenance (periodic re-coating), no matter what. Cetol seems to last as long as any of them, but even that will require replenishing in two to three years. Same for marine varnishes, catalyzed polyurethanes and everything else I ever tried. In informal tests, I never found any that lasted more than two years without starting to craze and break down.
My old formula, passed down from my dad, was to put three coats of marine varnish on when the piece is new, followed by one coat every year like clockwork. That's how he used to finish picnic tables and outdoor furniture, and the finish never broke down. Good enough for me.
Sounds like a fun project. Don't forget to post pictures.
Funny you should mention your sailboat. Just yesterday I pulled the sailbag out of my 14' boat which has been sitting in my tractor shed, unused, for many years. I decided it's time to start getting rid of some things I have and no longer have any use for. I thought sure the sails would have been mouse-bitten, and ruined, but they were fine. Anyhow, this is a plywood and redwood boat I built in 1960. At that time I used weldwood glue, and coated the redwood seats with a marine spar varnish. Suprisingly, the seats are still halfway glossy and unpeeled, even after 50 years! I have no idea what brand of varnish this was. I'm sure it was not costly. As to the tiller, I'd just used a piece of white oak left over from the boat, shaped and cut with a slot in the end.
If your boat was sitting in a shed it would be protected from the sun. The UV rays in sunlight is what causes finish to break down. No sun = no break down. I would like to see a pic of the boat you built 50 years ago; I bet it's nice.
