Maple "quandry"...
I have a piece of true 10/4 maple that's about 7" wide. It has "more kinks than a dog's hind leg". It is has some twists, bows and what not. I decided to cut off a section (2-3') so I could turn some pieces. Anyway - after I had trimmed it and cut it, I discovered why it was so unusually shaped. None of the grain is straight or even in the pieces that I cut. I also found a fair bit of chatoyance.
I have the rest of the board left. I've got maybe 10' or so. I'm thinking that there is some really interesting grain patterns what with all the twists, etc. I also think that the chatoyancy may carry through the board.
As it is so twisted and bowed - it is not like I can get any even cuts. I was planning on cutting it into short lengths (2') and just making legs and stretchers out of it. Now that I see the grain pattern and the chatoyancy, I don't know if that's the best idea.
I'm thinking about cutting it into smaller lengths and then resawing it to about 5/4. I figure I could easily get enough for a table top. I could probably get some decent boards that would at least be 1" or greater in thickness and about 6" in width.
The clamp guide is a bit over 4' x about 2".
Here is an example of the grain - though the picture really doesn't show the chatoyancy that is there.
What do ya'll think would be a good cutting protocol? Should I save it for table tops or what? It is kiln dried maple. Should I let it "relax" after cutting and before planing and jointing like I do for air-dried lumber?
Thoughts, opinions?
TIA
