What's a typical splay angle?
Nat Robison
.......for bar stool legs, etc.? As near as I could measure with a cheap protractor, it looks to be about 15 degrees.
Re: What's a typical splay angle?
Clint Searl
Clint Searl
Enough to keep it from tipping when a seated drunk is listing at 25 degrees.
Clint
Re: Listing
Be that Port er Starboard thar, Matie?
It depends on what size seat you have (yours and the chairs :D ).
It also depends on the height of the stool. I would expect a reasonably tall bar stool with a "reasonably" large seat to have rake and splay angles to be on the order of 10-12 degrees. Too much more and the legs would stick out too much.
That sounds like too much to me.
Keith Newton----Little Rock, Arkansas
I would be thinking around 5 ~ 7.5� from plumb would be plenty. Of course, that would depend on the height.
If the height of the stool was about 30" tall, 15� would be 7.5" out of plumb.
At 28 5/8", every 1/2" along an arc with the radius of that length is 1�.
Clint Searl
Aarrgh!
Clint Searl
Trick Question.
Answer:
Don't matter long as ye keeps the rudder wet, the sails dry, and don't spill the rum!
Yo Ho!!
According to Uncle Roy
Al Kapocius
Wuncet upon a time, Roy Underhill of the Woodwright's shop recommended 7.5 degrees as the splay angle. Figure it this way; 7.5 is half of 15 which is half of 30 which is half of 60 degrees.
Al Kapocius
Not to mention
twice as much as 3.75 degrees.
