Serving Tray ???
Serving Tray ???
Serving Tray ???
Ray - Middletown, IN
Wife wants some serving trays with solid wood bases, in fact she has already bought the wood. What do most of you do to allow for expansion with a solid wood base. I've got a couple of ideas but would like the collective wisdom of all.
Ray
Re: Serving Tray ???
Select the boards that are closest to quarter sawn that you can. Less movement that way.
I usually use screw slots in similar situations. I don't worry about the "sides" as they really won't be moving. I do worry about the ends. I usually fasten them in the middle and have screw slots closer to the edge. You might also design your trays so that the ends can slide into (and out of) the sides as your trays expand and contract.
Moses Yoder
Moses Yoder
I would groove the sides and then rabbet the bottom so it slides into the sides. Leave some space on the edges for the bottom to move; you could use space balls similar to a raised panel door to keep the panel centered, or you could glue the center of the panel at the ends and leave the sides unglued so they can move.
I'm with Moses
Lee Schierer McKean, PA
I would build them as described by Moses. The amount of expansion/contraction space would depend on the wood variety being used.
Lee
She already has a dead flat sawn board,
gotta quit taking her with me to the mill.
That is one of the options I thought of but I seem to be moving toward fastenerless assembly. (Is that a word?) For my nieces I may use screws as they will get much more abuse with their kids roughhousing around.
Thanks,
Ray
That's the other way I thought of
and probably the way I'll go for most of them. The other thing I thought of was slicing it into veneer and using ply as the substrate. I do like the idea of using solid wood though, I think it's more pleasing. At least to me and that's the first person I have to satisfy.
Thanks,
Ray
I've made one like that before.
John E in SC
Used a "floating" solid panel in dados. Prefinish the panel, and no fasteners needed. Made one that way 10+ years ago, and still looks great.
Me too, except...
... the part about space balls, at least without a caveat. They're made for cabinet door stiles, which are usually a couple inches wide. You can make the grooves in the stiles a little deeper to allow room for the space balls and any contraction of the panel. Thin tray sides, on the other hand may not be stiff enough to resist the space balls if/when the bottom expands, plus, your grooves might have to be too deep for the thickness of the sides.
Make the end grooves with little or no headroom and use a dab of glue or a pin of some sort in the middle to keep the expansion and contraction centered.
Bartstar
Not sure why the need for solid wood? It is not the prefer way to make a tray IMHO due to the wood movement factors on such a large panel. I have made several trays, and veneered the panel with cool stuff you could not get in solid panels. I always use a 1/4" plywood substrate.
That's purty.
A lot nicer than the board that was picked out. Since the BOSS picked out the wood and the project it my job just to make the trays appear as if by magic. She did pick out a really nice piece of ambrosia maple a little better than 10" wide and 16' long.
Ray
16' !!!! Ought to get at least one tray
Dick Coers
