Epoxy
Epoxy
Epoxy
Due to a mid-course correction by the client resulting in gaps in leg mortises, I'm going to be in "gap-filling" mode when I glue this leg-set up. I therefore plan to use epoxy for the glue. I have System 3 general purpose resin with fast or medium hardener but also plan to bulk up the mix to at least yogurt consistency to prevent the glue from running out of the joints. It's my understanding that wood flour or silica is the preferred thickening agent. Since I've got more than enough flour caked in my 7' DC bag, I figured to use that.
Has anyone here done this with epoxy? and if so, what were the issues you faced.
Thanks
Re: Epoxy
Re: Epoxy
John McGaw
Might it not be easier and stronger to fill the "bad" mortises with correctly fitting plugs and then re-cut them in the correct size and location? I have only ever filled catalyzed resin with glass micro-spheres (boat patching) but the only problem I ran into was getting the mix just right so that proper wetting occurred but sagging was avoided -- it was a fine line.
Re: Epoxy
Re: Epoxy
Hi John,
From what I gather, using wood flour makes the mix sag free but still wets out, but thinking about the wetting issue I was wondering if I would save out a smallish part of the mix before adding the flour, and then prewet the surfaces with that. The legs are already composite glue-ups and the fill spaces aren't that big.
Re: Epoxy
Re: Epoxy
Mark I've been playing a lot lately with thickening epoxy. Look at my cupcake icings. So far I only have experience with West systems but I think others work the same. Fillers weaken the epoxy. Too much filler and it may not harden correctly. I have used 3 different fillers from West systems and they all change the epoxy in different ways. Some harden softer than others which makes me think they don't make as strong a joint.
My advice would be to glue real wood to the joint and recut it if possible. If you must fill it with epoxy and filler do a test. I would do it by weight if possible so you can duplicate the percentage of quantities.
I have played with powdered tempera paint, coffee, sawdust, and the 3 west system fillers. All work differently and change the characteristics of the glue but they all thicken it. Beyond about toothpaste thickness is where the problems come in.
Re: Epoxy
Re: Epoxy
Justin Szeliga
West System & Gougeon Bros. have some great info on epoxy, one thing I recall is that non-sag consistency is like peanut butter. Cleaning up any squeeze out or oozing needs to be done when the epoxy gets to a rubbery hard stage. Let it cure overnight & it's a real pain to trim back.
I mix wood dust & saw dust with epoxy to do repairs & filling & the one thing I always learn is if you want to use saw dust as a filleting or surface filling compound you really can't have it too fine. Getting just real fine dust is a bit of work, & you'll need very fine dust for the filling you're talking about.
Re: Epoxy
Thanks
When it comes to fines, I've got the dust cake from a 7' high DC bag that I'll knock down into a bucket. Don't think I'll get finer than that.
As far as squeeze-out is concerned, I'll be applying the first two stages in finishing (oil and a double spitcoat of shellac) before the glue up, then sealing the joints with tape.
It will be interesting.
Re: Epoxy
Jesper, Denmark
Re: Epoxy
Jesper, Denmark
That is the standard operating procedure. It also allows you to make the thickened epoxy as stiff as you want.
Just for reference, the amorphous silica thickener only changes the viscosity of the epoxy, it does nothing for the strength of the joint or gap filling. The wood flour is good, but so is the high density fillers, like any number of minerals in crystal form, cotton fibre, etc.
Re: Epoxy
Thanks Jesper
S.O.P. is what I figured. :)
