Mortising Bit
Mortising Bit
Mortising Bit
Doug Reynolds in Seattle
Greetings from the Great Pacific Northwest. Can power mortising bits be sharpened when one of the "wings" gets broken off or, do I pretty much need to buy a new one? Also, these things make a pretty ragged hole when making a through mortise which I smoothed with a paring chisel. It just seems to me the tenon will never fit the exterior opening perfectly thus leaving some gap showing here and there. Is that gap acceptable even though the joint still is a friction fit? TIA for you guidance.
Re: Mortising Bit
The Wingless Bit
is toast. Those wings are essential to control of the bit.
To get precise fit on the outlet for through tenons, set your tool such that the only the bit's wings penetrate all the way. You'll then have a line of round holes, and you can trim the opening to meet your tenon using a 1" bench chisel. Pick is an example
