OT- Soldering
OT- Soldering
OT- Soldering
Thomas Norton
Though I can solder copper pipes and fittings I would like some info on a few other "projects".
I am into archery and want to fabricate a sight for my bow. I talked with one guy who took a small section of 1/2" copper pipe and soldered it to a piece of threaded rod. I tried it by drilling a hole and then using flux and my plumbing solder. It works but does not seem very secure. I would like to try a few other combinations like a brass/bronze washer to a threaded rod. but not sure if there is a"right" type of solder to use.
Advice?
Thanks
Re: OT- Soldering
Re: OT- Soldering
John McGaw
Plain old tin-lead solder with the correct flux and sufficient heat should do the job if the metals involved are amenable to soldering. My first guess would be that your "threaded rod" might not fit into that category. What sort of material are you using for the rod? There are special flux preparations made for use with steel and iron but right off hand I don't know where I'd go to find someone selling them.
Re: OT- Soldering
Re: OT- Soldering
Thomas Norton
My first attempt was just the plan "steel" rod I found at a hardware store. I did a search this AM and found that McMaster/Carr sells threaded brass rod fo about $9.00 for a 72" length. My the brass rod would be a better choice?
Re: OT- Soldering
Re: Copper To Steel
Thomas,
When using tin solder on steel, you need to have the steel very clean and free of all grease or oil. If you have a powered wire brush, clean the area where you want to attach, then wipe with alcohol or lacquer thinner, apply your flux, and "tin" or pre-solder that section of rod. Once you have a good bond on the steel it becomes easy to get more solder and your copper to "stick". You do, however, want to get maximum contact between the parts.
You can, or course, go with brass thread rod, but if you have a good hardware store around, you should be able to get a brass or bronze bolt in the correct size and save having to have your heirs deal with dividing up several feet of brass rod. ;)
Re: OT- Soldering
Re: Copper To Steel
Thomas Norton
Is there a special flux that I need or can I use my "plumbing" flux?
Re: OT- Soldering
Re: Copper To Steel
John McGaw
For copper or a copper alloy your "plumbing" flux should be fine. Another source of a potentially-solderable threaded rod would be a long closet bolt with the head sawn off. I believe that these are available up to around 2 inches which may or may not be enough for your needs. Otherwise a well-stocked hardware store should have brass machine screws which may be longer. I really have no idea how long the shaft for an archery sight would need to be -- I miss using the old-fashioned method.
Re: OT- Soldering
Re: OT- Soldering *LINK*
Bill Turpin in WNC mountains
Check out the WC article written several years ago. Price of silver is up. It has a tensile strength of 90,000 psi/sq in. Do not use any galvanized parts.
WC article
Re: OT- Soldering
Might be heat problem
Ray - Middletown, IN
The copper will heat faster than the steel rod probably. Preheat the steel if possible,tin it then put copper to it and solder together.
Ray
Re: OT- Soldering
Flux
Plumber's "grease" is OK for tin solder. The key, again, is clean metal surfaces. Flux, which becomes active of high temps, is there to improve "bite" on the metal by the joining alloy.
With all that's been said, my preference would still be brazing the copper to the steel using flux-coated bronze brazing rod, but that takes way more heat than a small LP torch can put out. MAPP gas may do it for brazing, but the torch of choice is oxy-acetylene. I may, however, be prejudiced as I learned to weld on am acetylene set and I've been passing gas ever since. :D
mm
Re: OT- Soldering
Re: OT- Soldering
Marv
Thomas,
Soft soldering like what a plumber will use on copper pipes has a lot to do with the thickness or size of the object that is being soldered and does not require as high a temperature.
The thin wall copper pipe for example can also be hard soldered or silver soldered, or silver brazed, all meaning the same thing. To get silver solder to flow well, it will need more heat than soft solder. When properly prepared, silver solder will produce the best looking joint and a strong joint as well.
There's lots of different soft solders each requiring different amounts of heat. Some will flow at very low temps, around 300 degrees or slightly less. Kester makes an excellent flux for all soft solders. Some soft solders will have a flux core which means there is flux inside the solder. You will still need to use flux on the object you are soldering. The flux helps clean the metal and prevents oxidation. The Kester flux used in the electronics industry is acid-free flux, that's the stuff you need to use. Acid flux is more difficult to clean off when it gets down in the nooks and crannies. You might talk to a Kester rep and explain what you are doing. They will tell you exactly what you need.
Acetylene brazing or welding is normally used for thicker metal and larger objects but can be used for small stuff too. To get brazing rod to flow you need more heat than for silver solder. I use my acetylene torch for silver soldering and brazing. I can adjust the heat based on the size of the flame. Flame size is determined by the tip size and by how much gas is feeding the flame.
While it is possible to soft solder using a torch and many people use that method, I have a large soldering iron that I use for most soft soldering.
People take classes to learn all this stuff. It really isn't possible to cover all the details here in a short message. Hopefully there are some helpful pointers in all this blab. :)
Marv
