Salvaging Flashlight with leaky battery question
I have a Mag lite that was under the seat in my truck and the battery leaked. Its the one at the butt cap. And its really stuck. Is there something that will dissolve the crap? I have scrapped and banged, but no luck.
Re: Salvaging Flashlight with leaky battery question
Joseph Mulherin, Sr
Barry, try using a heat gun to heat up the cap ....might loosen enough to unscrew...then cleanup the interior with some vinegar and a toothbrush. When reassembling apply some lubricating oil or pipethread tape to prevent sticking again.
Jim DeLaney, Austintown, Ohio
Contact MagLite. I'm pretty sure they're lifetime warranted.
They replaced one for me, but that was about ten years ago.
What battery?
Hoa in Alameda
I had the exact same problem.
The battery cells were Duracell. They have a warranty that they will replace equipment that is damaged by their batteries.
So I sent them the flashlight, with the battery cells still stuck inside.
A few weeks later, I received a check about the value of the flashlight + a $20 coupon of Duracell products.
MagLite will replace depending on mfg of battery
Terry Alexander
Had the same problem. MagLite has a relationship with a couple of battery mfgs. I can't remember which one. The battery had been in there so long that I couldn't get the light open....even with a couple of adjustable pliers.
Sent to MagLite and they said if it was xxx or yyy (can't remember) batteries inside they would warranty the light. 10-14 days later....here comes a brand new maglite.
Hope your luck was as good as mine.
Terry Alexander in West Texas
Re: MagLite will replace depending on mfg of batte
Frank Orfanello
I had the same experience.
The Mag told me if the batteries were Everyready or Duracell then they would replace the light. In my case they were duracell batteries and I got a new light by return mail.
i'll keep buying Maglight!!
