Sliding dovetail procedure
Bill Tindall
....as practiced in Mack Headley and Sons shop (more or less). I use an aid or two that the professionals don't need to bother with. I cut the male part first with a router. One can use a router table but I made a device for this task.
Step 1, mark it. The outside marks define the total width and the internal line marks the width of the part to be removed. I add a guide block along the outside line and you will soon see how it is used to overcome my inexperience in these matters.
Step 2, saw the outside face of the dovetail and saw somewhat inside of the angled face scribe line (how much inside depends on how good you can saw. I leave the scribe line to be removed later. On a stopped dovetail one can saw well beyond the stop line, and I do. Makes the next step easier.
Step 3, chisel out the waste
Step 4 true up the perpendicular face. The guide block again compensates for my lack of chisel skills.
Step 5 true up the bottom. This handy tool makes this task easier but it is by no means essential. This tool does do a nice job of cleaning up the corner between the vertical face and the bottom.
Step 6 true up the angled face. My router bit for the male part is 14 degrees so I made this guide block 14 degrees. Line the guide block up on the scribe line, securely clamp and pare away. The chisel needs a flat back and it must be sharp. Take light cuts, about 1/32 deep at a time. When you get the rhythm it goes amazingly fast, if the chisel is sharp. I make downward arching cuts starting at the back and working forward.
Modifications: Cut out a dado with a dado blade or router or router plane. Then with guide block cut the angled face
A perfect fit for a sliding dovetail is +/- 0.002 inches (I have studied these things, so the accuracy of the guide block location is important. As I was instructed, a well fit sliding dovetail can be slid together by hand pressure only. If you have to drive it together when dry fitting it is too tight and you risk it seizing up when the glue is applied and it swells. I do not angle the dovetail opening to get clearance; as it is unnecessary of the dovetail is fit right and I glue it full length.
Re: Sliding dovetail procedure
PS
Bill Tindall
The advantage of the one sided dovetail is in fitting. (also there is no question where the male piece will wind up; it will have one of its faces on one the the scribe lines, the one that was sawed perpendicular) I aim to make the dovetail socket perfect to slightly large. If the fit is too tight a swipe off the straight side of the male piece with a hand plane will adjust the fit. By the time I finished 38 of these I was getting perfect fits every time without adjustment and they were going quickly. It was taking me less than 2 minutes to remove the waste and get the fit right. This is a skill I will now use often as I make a lot of stuff that benefits from this joint.
Thanks much for this tutorial, Bill
It's headed for my library.
Those are really good, Bill, and thanks for
Bruce, a MN Galoot
the tutorial.
My sliding dovetails have always been double-sided, so it's good to know the single-side ones work just as well. They'd be a lot easier to make.
Big Dave
Great info, Bill! I have a feeling it will someday be put to good use...
Thanks!
Dave
Nice!  Thanks Bill!
Tony - Memphis
Device for cutting the male part(pin?)
Bill Tindall
With luck these pictures show the handy device I made for cutting the male part. It is fast! Clamp drawer blade or divider into the device, indexing the end flush with the top of the device. Pass the router over the end. Done. I like to use a foot switch on the router for these cuts. I submitted this idea to a magazine but they didn't think it worthy of mention in the tips column.
With this device for cutting the ends and the comfort I now have in chopping out the female part, the single sliding dovetail has become the fastest, and bestest, way to assemble a case with perfectly fit joints and little stress of a sliding dovetail locking up during assembly.
PS
Bill Tindall
What may not at first be apparent is that the thickness of the drawer blade, or divider, does not have to be precise. The pin, if it is fair to call it the pin, will be the same size no matter the thickness of the stock.
Jesse Cloud
Thanks for the tutorial Bill. Great pics, they really tell the story. Lots of clever ideas in this post!
Re: PS
Stuart Johnson
Thanks Bill. An email is on the way to you with a copy of your posts as a pdf file. If you approve I'll send it in for the articles section.
Re: PS
Chuck Kettler
Thanks for the pictures. I will use this technique if and when I get a new shop next year.
Great tutorial
Stephen Kirk
Love this jig for the tails. Thanks for posting.
New Improved Version of this procedure
Bill Tindall
I have done some editing to improve clarity, add detail and remove extraneous verbiage and the result will soon be in the WC Articles section. There is a detail I did not include in this series of posts that relates to making a multitude of sliding dove tails like for a chest of drawers. If the male part is cut on the drawer blades and dividers with the device illustrated, these parts will be precisely identical in size, which means the female dovetails will be precisely identical in size. Once the width of the dovetail is determined a gauge strip can be fabricated to repetitively mark the width of the female part. This strip is the piece of cherry with the black writing on it (that says "gauge strip don't throw out") seen in Pictures 2-5. After aligning the guide block with the outside scribe line (the walnut plywood piece in the Pictures) one side of the cherry strip is pressed against the guide block and a scribe line made along its other side. The result is the internal scribe line shown in the first picture. This scribe line and the plywood guide block establishes the width of the female part of the sliding dovetail.
Again, if they are precisely cut and fitted, there is no need to taper this joint, or only glue part of it, for there is no risk of the joint prematurely seizing during assembly. The criteria for proper fit is that it can be dry fit with hand pressure only.
One small detail
Al Goldstein
Bill,
Great post. I'll be using sliding dovetails from now on.
One more detail you forgot to mention in your write up - a method for setting the depth of cut of the dovetail bit. I think I see a little notch in one of your pictures of the fixture for cutting the male dovetail that could be used for resetting the dovetail cutter depth. It was created at the beginning of the dovetail cut. I assume that you start the cut from left to right at the back of the opening in your fixture and then pull the router toward you to make the cut on the clamped piece.
You also could use the dovetail bit to cut a groove at the front edge of the fixture for setting the dovetail bit depth.
Thanks also for the tip on gluing the joint.
Al
I've been caught!
Bill Tindall
The drawer divider "prop" is installed to best show features of the device, not actually use it. In use the part to be dovetailed will be installed on the front side of the opening and the router pulled right to left against the guide fence, that sophisticated piece of 1/4" something fastened with two C clamps.
The female part of the sliding dovetail is fit from the male part so it is not critical about setting the router bit depth. But, as you suggest, the marks could be used to set the depth. I'll remember that next time I use it.
