WB Poly Question
WB Poly Question
WB Poly Question
Nat Robison
I did my floors a few years ago with a WB Poly that came in a plastic jug. I kept the jug after it was empty and put a gallon of a different WB Poly (that came from a can) in it. I opened it yesterday and the poly is a milky tan color. To my knowledge, nothing else was ever in the plastic jug. I used some and it seems to work OK and go on clear.
Any thoughts as to why it changed?
Re: WB Poly Question
Speculation
Bill Tindall
It may come as a surprise but oxygen readily passes through polyethyene. Oxidations often result in something turning dark-yellow, brown or black. It may be that the stuff in the can was in a can, and not a jug, because it is sensitive to oxygen, like beer.
It takes but a tiny concentration of discolored stuff to look "bad". So what ever this degredation product is there may not be enough of it to affect performance, or color in a thin film.
Throw It Out
Howard Acheson
I would not use any finish that is over a year old. While it may look like it worked OK, waterborne finishes work by chemicals coalescing when the water evaporates. It is highly likely that the surface is dry but the follow-on process did not work correctly.
Finish is not that expensive the in grand scheme of things and it's not a good idea to be frugal in this area.
Also, Bill is absolutely correct. Many plastics are not impervious to oxygen migration. That's the reason they have not been able to put beer into plastic containers.
Junk it.
steve mackay
