Dovetailed drawer dividers
Gary Smyth
I need to insert matching sliding dovetailed vertical dividers in the top two 4" openings -- at about where the band clamp is. The dividers are to be centered in the horizontal drawer openings. In making the shallow dovetail tails I thought that I saw a router jig (sled?) that would provide the support and side to side precision needed to be certain that the dovetail pin dividers will align vertically with one another. The pins are less of a challenge, it's the tail cuts that I want dead on, straight through, with no tear out, and aligned. If I use a dovetail saw and chisel to plow it out I'm concerned that my skills are not good enough. If I used my router table I have support only on one side of the long horizontal divider and I'm concerned that the piece will skew when pushed through. Anyone remember an accurate (sliding?) jig that will support a long piece for a perpendicular rout?
Re: Dovetailed drawer dividers
Re: Dovetailed drawer dividers *LINK*
del schisler
This system may give you a idea. This jig is a little bit $$$'s But watch the video.
http://us.oak-park.com/catalogue.html?list=RTS-MGS-
Hand-rout them
I'd just make up a T-square type fence, clamp it across the rails, and use the blade of the fence as your router guide.
Like this?
Bill Tindall
I can chop one in less than two minutes by hand and with the guide blocks employed it is fool proof. I have it all described in pictures but I am not up to formatting them all to achieve the Woodcentral limits for posting. If you are interested I can email the process description to you directly. (yet another thing I learned in the Headley class I took). I chopped 38 of them in this chest of drawers.
Jesse Cloud
If you choose to use a router, consider making the pins and the tails very slightly tapered, say 1/16 over a foot. That way the fit doesn't get snug until the very end, much easier to install. You can use Ellis' T-square method and put a couple of pieces of tape on one end of the T, similar when routing the tails, put a couple of pieces of tape on the end of the board and slide it along the fence.
Yes.  Message sent to your e-mail.
Gary Smyth
Re: Like this?
Tony - Memphis
I've only done a few of those, but I was taught to do them by hand. We made the divider first. The pin was not that deep - maybe 3/8". After it was done, we put them in place and scribed the outline to act as our guide to clean out the socket. We rought sawed first, then finished up by hand. We made a jig too. a simple piece of wood cut at the appropriate angle and clamped to the workpiece to guide the chisel. I won't claim it was foolproof, I can mess up anything, but it wasn't as hard as I imagined it would be. My joints came out pretty decent for a rookie. Bill, I'd love to hear more about how you learned. Is that the same chest with the french feet? I'm anxious to see more on those too! Thanks for sharing.
Tony
Tony
Re: Like this?
AZ in Colorado Springs
Last spring I made a small blanket chest for my daughter. I used the plan that was published in Popular Woodworking in late summer 09. The chest has two drawers beneath the blanket compartment, with a similar divider between them. I did likewise; cut the tails (by hand) first, and used the divider as a pattern for the sockets. The sockets were only 1/4" deep. Turned out well. Take your time, and make a practice joint on a piece of scrap of the same species/hardness, to get the feel of it (if you need to). It'll take an hour at most.
Good luck
FredD
If you have a Router Gary , I see no reason to weaken the Dovetail by only angleling one side of the joint.
It's true that speeds up the work , but it cuts the mechanical advantage of the joint in half , which is the reason we use the Dovetail.
I did a Chest some time back and all of the dividers are Dovetailed into the rails and the rails likewise are Dovetailed into the sides of the Chest.
Not all that hard using a router.
This is not a very good pic , but you can get the idea.
http://picasaweb.google.com/lh/photo/avVxP-qlHruVVdVh59zMKw?feat=directlink
http://http://picasaweb.google.com/lh/photo/avVxP-qlHruVVdVh59zMKw?feat=directlink
In defense of the half dovetail
Bill Tindall
Its principal advantage is in fitting, not speed of cutting it. The flat side enables the male piece to be planed on one side to coax it into a perfect fit. A perfect fit is desirable not only for mechanical strength but also for stress-free assembly. Too-tight sliding dovetails are notorious for locking up prematurely during assembly.
A lesser advantage is alignment. One knows exactly where the flat side will wind up in a half dovetail. With a full dovetail it is all too easy to get its location off a bit. Been there and done that.
The half dovetail is used where the alternative could be a mortise and tenon. Over the course of wood working history case pieces were dovetailed top and bottom with full dovetails and the drawer blades installed with mortise and tenon, half dovetails or full dovetails. There is a lot of furniture out there that has survived just fine where the drawer blades were M&T into the case sides. However, in my study of these pieces after 200 years there is frequently some separation of the joint between the case side and the drawer blade which could detract from the appearance. However, the top and bottom dovetails are holding the case together adequately.
Given where this joint is used, the additional locking ability of the full dovetail, compared to a half dovetail, is unnecessary. The drawer blade dovetail function in a case piece is simply to hold the sides into submission should there be any tendency to warping. The pieces I see in museums with half dovetails are as secure as those with full dovetails, and better than M&T.
If one is building with traditional hand tool techniques, there is one speed advantage. A dado plane is used to cut a dado across the case side. This quick operation establishes the perpendicular face for the half dovetail front and back, as well as a dado to accommodate the drawer runner. It is then a simple and quick operation to deepen the dado where the drawer blade will go and add the angled face for the dovetail.
