(Message Deleted by Poster)
Chuck Lenz
Chuck Lenz
Re: Shop Made Large Radius Compass
Merle
Chuck,
It looks good. How long did it take you to assemble?
Sweet! I love simple ingenuity!
Scott Burr in Ben Lomond CA
One step from a trammel
Bill Tindall
I have been avoiding getting a loan to buy a useful trammel. Staggering how much they cost! (Don't waste money on the cheap ones; they are useless) Your ingenious innovation has not only solved the compass problem, but trammel too. One could even cut and thread the rod and with the addition of couplers and with additional extension rods make a variable length arrangement that could be short and handy for smaller circles and extended for large ones. Thanks for the invention.
Hmm?? Interesting possibilities....
Great looking sue for whats on and. I love making something out of nothing. "Nothing" being stuff I have laying around.
How would it work to use a threaded rod and two couplers? One coupler could have the pencil and the other one a point. My first thought was that would limit the adjustment to whatever the thread pitch is, but you could compensate for that by making it possible to put the point in either end of the couple and that would reduce it to half the pitch. And you could put the point on the pivot off center so that you could rotate it eccentrically inside the coupler and use it as a micro adjuster. A set screw could lock it in place after you rotate it.
Thanks for the inspiration. This is a great invention.
Paul Cates - Henderson, KY
Nice job! Now I want to make one for myself because you came up with such a great design.
Leo Cuellar
Great job, Chuck! One sweet idea. A smaller version of that would also be useful to chuck into the drill press to make sure the table is level.
Chuck Lenz
Re: One step from a trammel ( closeup )
Brint in Richmond, VA
Well done. Thanks for sharing.
I have a simpler, more accurate solution.
Keith Newton
Chuck that is nice, and I like, but it has the potential to flex along the beam, that may allow flair between pin and pencil.
My simple solution, is to start with a thin batten, then either drill, or stab an awl through for the pivot. I then stab the tip of my knife through, to scribe the surface of solid wood, or to cut all of the way through veneer.
When I'm done, I discard it. There is always a usable scrap laying around in my shop
Howard Norman
I like it enough to make one for myself.
howard
Excellent!
Alan Young
Re: You didn't finish them...
Rick L
http://www.toolfetch.com/Category/Measuring_Leveling/Calipers_Dividers/318-523.htm
Notice the General trammel heads have eccentric points for fine tuning your circle. For the time you spent I thing the General trammels are a better deal. The Lee Valley ones are more but even better trammels.
http://www.leevalley.com/US/wood/page.aspx?p=32627&cat=1,42936,42938
The design and engineering is just as important as the execution of a project.
Pretty snazzy, Chuck!
Bruce, a MN Galoot
Chuck Lenz
Re: Constructive criticism
Rick L
I have the Starrett, General and LV. The Lee Valley trammel is the superior one. Starret is over priced but the accessories are not to be found anywhere else. I did buy them at flea markets over the years. Hope you get to try one and see why the eccentric adjuster of the points are so great. Then maybe you will finish your trammels.
Chuck Lenz
FredD
I would be proud to own a similar layout tool that one made because he could and because it was a challenge.
BTW, did you make two? ;-))
You really do need to keep your fence and blade relative to each other though.
FredD
