Best sandpaper?
Best sandpaper?
Best sandpaper?
Pat Evans
I ran out of Klingspor 220 grit aluminum oxide and switched to the Harbor Freight, made in India, 220 grit aluminum oxide that my wife picked up for me. I had no idea sandpaper could be that different. The HF cuts slower and clogs quickly... just the opposite of the Klingspor. I can do 5 or 6 times more sanding with the Klingspor. (No affiliation... just saying.)
Is there a better brand than Klingspor?
Re: Best sandpaper?
Re: Best sandpaper?
Marv
Pat,
Don't know if it is better than Klingspor, but I have found that the black 3M product that you can buy at Walmart is the best I've found. It too cuts fast and lasts longer.
Marv
Re: Best sandpaper?
Don't know if better, but I like Norton 3X
Charles Yawn
Re: Best sandpaper?
Problem . . .
steve mackay
The Best is NORTON 3X . . . problem is I have to lower myself to go into The Orange Borg to get it.
Re: Best sandpaper?
Don't know, but the stuff I like is
Bruce, a MN Galoot
any sandpaper built on "P" grade paper. It's the heavyweight backing, and that usually comes stearated, so it doesn't load up on you. I just went to look at the stuff I have now, and it's a brand I don't recognize from Canada, P grade and absolutely wonderful - got it from Tool Crib of the N.
I can get 3M sandpaper here for $.01 (there doesn't seem to be a "cent" symbol on my keyboard) but unfortunately what they sell in the employee store is the lightweight paper. But it's cheap.
One piece of advice I saw on sanding is to use it like it's free.
Re: Best sandpaper?
Re: Don't know, but the stuff I like is
John Pappas
Bruce, hold down ALT key, enter 155 on numeric pad, release ALT key, and you get �.
Google ALT CODES to see complete list.
Re: Best sandpaper?
���  Cool! but the alt key is missing from
Bruce, a MN Galoot
my Imac. Thanks to your prodding, I found Option "4" key
Re: Best sandpaper?
Bruce, I'm no expert but I think the P is a European Standard (Or at least not from the US) that has to do with the designation of the grit size not the paper weight. Maybe somebody will jump in, but I believe the P designation indicates the paper is one grit coarser than the American stuff. Or maybe its the other way around.
The paper has a letter designation also. I think it starts with A weight and may be up to about K Some are cloth backed and some have reinforced paper that has been stabilized so that it won't stretch on things like belt sanders and drum sanders.
And then there is a whole book's worth of stuff about the grits.
Re: Best sandpaper?
Steve Schoene
In the coarser grits the traditional US standard(CAMI) is about the same as the equivalent P designation. But above about 220 grit the two standards begin to diverge so that CAMI 320 just marginally coarser than P400 and CAMI 400 is similar to P800 and CAMI 600 is between P 1200 P2000. They do differ in other ways--such as how uniform the grits must be. Mostly however the differences in papers don't relate to the sizing standard as much as how well they are manufactured and the type of paper.
Re: Best sandpaper?
order it from Woodcraft
We don't have the big box stores here so I'm pretty limited to mail order if I want decent sandpaper.
Re: Best sandpaper?
learn something new every day!!
Bruce, a MN Galoot
Here I thought the P in my P 120 sandpaper indicated paper type. Then I learn that it means grit grading standard.
Yup, my sandpaper is made in Switzerland. And the paper is nearly stiff as cardboard. It is stearated and almost never wears out. I love it. Well, "love" as in really like, well, you know...
I mean it's really good sandpaper.
Re: Best sandpaper?
Re: Best sandpaper?
Jim Dillon
Pat,
Another vote for the Norton 3X line of sandpaper. I have used Klingspor for a long time, but like the Norton sandpaper a lot as well. Norton 3X is available from Amazon if you are not close to a Borg store.
Jim
