Removing old yellow glue? - I think
DouginDenver
I have a four-legged tea table that has a turned center post that the top attaches to. The top of the center post was glued to a larger wooden disk (about 5" diameter) that in turn was glued to the top. I have to make a new top, and the disk was not round, so I have to make one of those too. I cut the disk off and chiseled all the wood away from the center post, but I am left with the glue. This is not a thin glue line, but a big globby thick layer at least 1/16" thick if not more. I'd guess it's 1940s era, but this is not hide glue. It's kinda yellow and is kind of shiny. I can't imagine getting a modern PVA to dry in a thick layer like that, but it looks most like a PVA. What might remove it? Very hard to get leverage on a thin turning to use a chisel and that won't get it all anyway.
Re: Removing old yellow glue? - I think
The "traditional" means of removing glue are heat, moisture and a combination of heat and moisture. I've got a heat gun that I use upon occasion.
I've used dilute acetic acid (concentrated white vinegar) to soften glue. I've also used dry ice to "freeze fracture" glue (apply the dry ice and then give it a sharp rap with a dead blow hammer).
Jason Roehl in Lafayette, IN
How about a miter saw?
Cut the glue off--take it 1/64" at a time or so. If you don't have a miter saw with the necessary capacity, use a sled and tablesaw. Even if you cut off a little of the wood, you could make the new disk a little thicker.
Jason
Thick
I am this morning. Trying to envision a 5-legged table (4 legs + the post), but not doing at all well with the attempt.
Can you post a pic?
I rather like JL's dry ice method.
Dear Thick,
I'm thinking it's a pedestal with four feet/legs. At least that's what my aging brain came up with and I, gong with that for now.
I might try the dry ice method. (Kroger Grocery store has it locally).
Or a rasp. If I had a dowel/tenon cutter I might try that.
If the swing of my lathe were big enough to accommodate the feet, I might give it a spin.
Re: How about a miter saw?
DouginDenver
This s good diea, but no miter saw. And the legs would interfere with reaching the table saw blade. I'll think whether I can do it accurately enough on a band saw. For the others - yes it has four angled legs at the bottom but only a turned center post under the table. The disk of glue I need to remove is about 2.5" in diameter.
Marv
Sounds like a job for a small right-angle disc sander.
Marv
No Fair
Most legs has feets.
Most feets has legs.
But they's differn't.
Joseph Mulherin, Sr
Doug, have you considered one of those multi purpose tools like Fein. They sell like tools at
Sears, and Harbor Freight has one at a very low price which might be just the tool you need.
Look at their website: www.harborfreight.com and view what it does very nicely.
I like the dry ice idea....
John in NM
but then I like that kinda stuff.... liquid nitrogen would be fun too (almost a gas even :D )
Short of that though, steam is the route. Kettle with a cork and tubing, wrap a rag around the tubing so you can send it right to the problem area. You can also use copper tubing and superheat the steam with a propane torch. You can easily get the steam hot enough to burn the wood, so be careful if you try that.
I've never really bought into the vinegar thing, I'd always understood that its really more for hide glue.
Vinegar seems to have worked
DouginDenver
I puddled some vinegar on this morning and let it sit 20 minutes. Turned it into a white muck I could scrape off. Thanks.
