Caster problem fixed
Stephen Kirk
The problem was that when the hinged plate was lowered the plate of the caster wasn't parallel to the floor. The hinged plate is about a 15 deg angle so I put some 15 deg wedges under the caster and now all is fine. I had to recess the wedges into the plate to maintain my clearance.
Thanks for the suggestions on what to look for! I'm rolling now!
