We value your privacy.
I have read(WC) that you have refinished/repaired furniture,etc. I have been given the task of refinishing a palladium door/window on a PAINTED(WHITE) corner cabinet with a different twist! The door/window was striped the same time as the cabinet was but it was never completed. The door/w still has all the stripper on it (dried of course) when it was started 5 or six years ago. It also has mold spots on 25% of the piece. I'm sure the stripper has penatrated the wood fibers as well as the diluted paint from the stripper. The customer wants to use a light colored finish the same as he did the cabinet. At this point I have not seen the cabinet. He told me the cabinet is made of pine.(??)
I've done alot of furniture over the years but this is the first one that i've started in this manner.
YOUR thoughts George and anyone else's.
Thanks, Rick
Re: Question for George Dart and other refinishers
David Yoho
Rick, I don't foresee any problems based on your description. Earlier this year I was hired to refinish a desk that someone else had started stripping but stopped mid way. I also had a job where I had to strip a very old fir exterior entrance door that was painted white. Both jobs turned out great, although the door took more time and effort due to the many layers of paint that had to be removed.
I've always used a strong semi-paste chemical stripper made by BIX that gets the job done in fine fashion. I see folks using all types and brands of stripper, which may or may not work as well. The bottom line is - the BIX is nasty stuff that does what it is intended to do. To remove the stripper and old finish I use a combination of putty knives, picks, and green Scotch Brite pads. Since your wood is soft, pay close attention to not gouging it as you clean away the old finish.
No matter what you use, be prepared to thoroughly sand the surfaces once the stripping is complete. This will help further remove any surface film from the stripping process as well as smooth the wood in preparation for a new finish.
Unless there's something I missed in your explanation, that door sounds like a straightforward strip and refinish job to me. I don't think the previous attempt will cause a problem because the new stripper should pick up where the old left off and take the paint off.
David
Chuck Lenz
Without seeing it up close and personal it's hard to say how big of a job that it is, and I'm not so sure that I would take someone elses word that it's pine unless I know that they know what they are talking about. I've refinished alot of antique furniture over the years, I got to the point that I didn't want to have anything to do with something that was painted. Not that I couldn't do it, but because it took so long to get the paint out of every nook and cranny, and sometimes the grain. People don't realize the time it takes to do it right, and when you give them an estimate they think your bending them over. Rather then going through the nasty replies and probably geting a bad name because of the bid I chose not to even consider anything painted, unless they absolutely begged me to do it.
I have to agree with David. I see no problems stripping off the old stripper and paint. Scrub with Scotchbrite to remove all residual paint, and then uniformly sand away what is left. Pine is soft, so it should sand out very well.
