Three Issues
1. Yes, you can switch, but you'll need to switch out to orifice(s) to the size required for NG and may need a different regulator.
2. No. Propane burns hotter than methane so your "stew" pot will take longer to boil. Any cost savings may be negated by the increased amount of gas used.
3. Caution. If you're switching from small-tank propane to natural gas, I will anticipate that you plan on tapping into gas service that comes from a main. It is "illegal" and dangerous to tap a NG gas line (or even a large LP tank) to supply a portable device, even with a cut-off valve at the tap. If you develop a leak it the item falls or is moved, the resulting explosion and fire will be continuously fed by the main rather than that small tank that is isolated. This is a Big Deal so don't do it!
