Has anyone made a router pantograph?
John in NM
I need to start duplicating some parts rather than hand shaping, so I'm going to build a duplicating machine and I'd like to hear from anyone with experience either building or just using one.
Option one is to spend a lot on linear bearings and shafts. Obvious plus there is tight tolerance and ease of assembly, the minus is the cost, more than $250 just for bearings.
Option two is to make a more traditional pantograph using a parallelogram design and simple bronze bushings that rotate and don't slide. Its a lot cheaper, made from scraps of wood and hardware store fittings, but doesn't have a lot of precision I'd imagine.
I believe what really upsets precision in these machines is vibration, so I'm wondering if the second option is built stout enough if it will overcome some of those problems.
Re: Has anyone made a router pantograph?
Rick L
Re: Bronze bushings, great, affordable
Rick L
There is a difference between a duplicator and a pantograph. William Schnute's book High Relief Woodcarving has a simple do it yourself duplicator.
Don't dismiss the simple bronze bushings and ssteel shaft. Just as accurate as the expensive linear bearing and can be made adjustable so there is a bit more friction. Sometimes you don't want it to slide too easy.
Good selection at www.mcmaster.com
Steve Kreitler
I've made a couple of router pantagraphs- a 1:1 from the old Wood Mag plans (downsized it a bit- didn't have room for that huge version in my little shop), and a 1:2 from a plan I happened across in an old magazine.
I've not used the 1:1 very much, but I've got some ideas for products and jigs that will be very useful with it. I've used the 1:2 pantagraph extensively, mostly with cut out templates (the follower rides in the cutouts, making it very simple to reproduce patterns).
I did an article on building the 1:2 version on my blog- it can be read here-
www.realrecycling.blogspot.com
total cost was under five dollars, I believe.
