200+ woodworking book reviews
Swivel casters don't swivel
Stephen Kirk
I'm finishing up a rolling kitchen island / cart. I have 4 2" swivel casters on the cart. The casters don't seem to want to swivel, they get stuck sideways a lot. The cart is small, about 20" x 36". I have the casters mounted on hinged plates with a sliding block so the island doesn't move when you don't want it to. Lift up the cart, slide the block in and now the casters are lower than the leg.
Could this just be a case of cheap casters? I used a basic industrial one from Lowes. The island doesn't weigh much, so I don't need a super strong caster. In order to let the legs lower to the floor when the hinged plate is closed I can't go bigger than a 2" caster, though.
Wondering if there are any ideas to make this roll better?
Re: Swivel casters don't swivel
Chuck Lenz
Have you tried some type of lubricant in the bearings where it swivels ?
John McGaw
Are you absolutely sure that the caster mounting hardware clears the swiveling portion when weight is applied? I have that problem on a big heavy laundry center I built -- even with heavy-duty industrial casters the weight pushes everything down far enough that my hardware (which I'm going to get around to grinding down some day) interferes with the swivel portion by a few thousandths and that is enough to gum up the works.
Lee Schierer McKean, PA
Make sure your casters are mounted square to the floor. They won't swivel properly if they are out of plumb.
Lee
Stephen Kirk
You were right on. In my case, the plate the casters are attached to is at an angle, so the casters are at an angle. That binds the swivel mechanism. I guess I can look for a caster with less play, or if I have the clearance I can put a wedge between the caster and the plate so when they are engaged they are level.
Stephen Kirk
Just what I found out!
How about ball casters? *LINK*
Since you have now identified the problem (points up), maybe you need to rethink the product.
I've never used these, but I would think they'd be less sensitive to angle of attachment, relative to the floor.
One example of many
Dual Wheel Casters
Bill Earl
I just finished a similar project. It is 30 x 36 with a 2 1/4" butcher block top and storage underneath. Most casters rated for the weight are either too wide or too tall. The wider ones take a lot of force to swivel.
I used dual wheel casters and they work nicely:
Re: Dual Wheel Casters - link
Joseph Mulherin, Sr
They also have a good selection of casters at the Harbor Freight stores at reasonable prices.
Re: How about ball casters?
Stephen Kirk
These are cool. They look as if they should work perfectly for my need.
Thanks!
Made in China
Pat Evans
I bought a set of casters from Lowes that also did not swivel. I found that there were so few ball bearings, that when swiveling, they bunched up on one side and the caster would bind up on the opposite side. I got my money back.
FredD
Stephen,
if you will note the information on the Ball caster site , Bill sent you the link to , it says"they are great for Cememt and Garage floors".
They will destroy Linoleum , Tile and Wood flooring.
I have made many of the Island cabinets and the ones we wanted to roll , we used Shephard Casters on , which come with Rubber or plain rolling contact depending on the type of flooring they rest on.
They are offset and the cabinet will not roll under normal use , so no brakes or blocks or needed.
FredD
