Flattening a benchtop
Nat Robison
Having grown tired of using my tablesaw for a "whatever" surface, I decided to build a bench in my garage for a proper work surface. This is nothing fancy, one side is anchored to a stud wall, two legs supporting the other side, the top is glued from ripped-down SPF studs (the most knot-free I could locate). A total of about $50 into it. Anyway, I glued up 2 12"-wide sections and glued them together. Problem is, there's a hump in the middle. So.........what's the quickest way to fix this?
Rip it down the middle, square up and re-glue?
I've seen mentioned a jig for flattening a top using a router. Is that the way to go?
I have to image that the router would take far longer than the first option. I'm not terribly confident about gluing wide, heavy pieces like this.
