200+ woodworking book reviews
Cleaning Solution
Cleaning Solution
Cleaning Solution
Howard Norman
Some time ago a good furniture cleaning solution formula was published here. I made it and used it successfully. Now I need to clean a fireplace mantel and I can't find the copy I printed out or find it using the search function. Can someone help me out? I think that it was posted by one of the UK members of WC.
PS
I just found it on my computer. It was posted by Sam Simpson back in Oct 03.
howard
Re: Cleaning Solution
Wow
your memory's impressive - I can remember 2003, but just barely.
Re: Wow
Howard Norman
It wasn't my memory that I used to determine the date of the post. It was the fact that my saved copy had the date on it. I don't want to take credit for having that good of a memory.
paul in AZ
I plowed around the search for a while and couldn't find it.
Perhaps you could share it with us???
Howard Norman
Paul, here it is:
Cleaning recipe
R. J. "Sam" Simpson. <rjsesqantq@aol.com> -- Monday, 20 October 2003, at 1:51 p.m.
Hi Y'all,
Lynn, I concur with Brian, your cabinets sound wonderful, don't change things.
But I can offer a better cleaning solution if the TSP doesn't get the darkness out of the finish.
Both Shellac and oil finishes will drink dirt over a period of time.
To clean the finish it is necessary to slightly soften the surface as you clean.
This will release most of the dirt and get you back to the original clean finish.
You can imagine, this is a little more delicate than just washing down,
but not such that anyone couldn't have a try.This is a recipe given out by the British Museum for
furniture restoration :-
8 oz Turpentine
4 0z Denatured alcohol
2 oz White Vinegar
1 oz Murphy's oil soap
1 oz Brasso
1 tea spoon household ammonia
Mix in the order given and shake well.
Test the area to be cleaned and find out if the finish is shellac (susceptible to softening with alcohol) if so you might want to back out a little alcohol, but it isn't necessary if you keep your eye on the work. If all is going well and you just would like the solution to be a little more aggressive, you can add a little more ammonia (but not more than double)
Use in a well ventilated area.
Regards Sam Simpson.
