WE MOVED...
Under cabinet lighting
Terry Alexander
The house is coming along fine. Upper cabinets are installed. FWIW....instead of building a bunch of "box" cabinets and putting them up, I built the uppers as a single unit. One wall is 55" wide by 66" tall (10' ceilings in the kitchen). The other is 89" wide and 66" tall. Took a car jack to get it up!
Went to Lowe's (you gotta start somewhere) looking for under the counter lights. Power is not a problem as we are going to put up a tile backsplash so I can know holes wherever I want. A contractor there said to go to a specialty lighting house and look for string LED lights. He said they are expensive, but well worth the money.
We did see 1 light at Lowe's that is battery operated and comes on via motion detection. I thought that was pretty neat.
NEWay....the kitchen is stainless steel appliances and black granite countertop. Cabinets are birch....poly...no stain.
I/we would really appreciate some opinions/advise on under cabinet lighting. I would say that "cost is not a problem", but we do try to budget (isn't everybody). Having said/typed that, we certainly don't want to put in something that looks "cheesy" with it looking like a million dollars right now.
As always....thanks in advance.
Terry Alexander in West Texas
Re: Under cabinet lighting
The LOML and I just put a Xenon fixture over the sink. It is nice, but it would be a bit tall for under cabinet lighting. The Xenon fixtures typically have two light levels. The lower profile Xenon fixtures are ~1" high the others are about ~1 3/8".
LED fixtures are also worth considering. I just figured I'd throw out Xenon.
pecker
My experience is:
Don't get low voltage halogen lighting. The bulbs have a short life and are kinda expensive.
I like the appearance of Xenon lights, plus they last about four times as long as halogen, and don't get as hot. But the bulbs are a bit pricey, too.
I still like halogen fixtures...
John in NM
Bulb+power=light.... keeps it reliable and inexpensive to maintain. Underside of the cabinet gets a little warm but not bad. LED's are pricey and from the few bulb styles I've used, prone to failure within a few years. And like CF, I just don't like the light, too blue.
Pat Evans
Not familiar with LED string lights, but they might be a good solution. I used "rope" lights under some cabinets and really like them. Somewhat lower light level than fluorescent, but warmer color and very uniform light.
Gerry In North Surrey
We have low voltage halogen under cabinet lighting and I spend more time than I should cleaning the bulb and fixture contacts and fiddling with the bulbs to get them to light. It seems that the moisture from normal kitchen activities corrodes the contacts and causes darkness. I looked into changing them and found some LED undercounter lights only 1/4" thick at a local lighting specialty store but they were out of my budget range. I found some that were reasonably priced at Ikea thinking I could replace just the fixtures (and not changing the transformer) but all I did was fry the little circuit board in the new fixture. I'm not about to dig out the old transformers from wherever they are so I'll just keep fiddling and cussin'.
David Barnett
LED lighting is a good choice *LINK*
David Barnett
I prefer strip LED lighting to string/tube LEDs, and I like the flex strips best of all -- even for straight line applications. For most interior work, I find 4000K to be a good color temp. 6000K is great for workstations, countertops and desktops, anywhere you want good visibility and low heat output -- I'm using 6000K in a tissue culture glovebox.
Initial cost can strain some budgets, but there's no maintenance and the energy savings are amazing. Installation's a cinch.
Here's a link for tape LEDs, but there are other LED options and suppliers, such as:
http://www.theledlight.com/index.html
And a guide:
http://tinyurl.com/23pukej
DL-FLEX-UP
Re: Under cabinet lighting *LINK*
Jim Dillon
Hi Terry,
I used under cabinet Xenon lighting purchased from Pegasus Associates Lighting and they have worked well and the bulbs (G-8), if needed, are available from the Borg. For display lighting, I went with the puck Xenon lights available at the time from Rockler; the latter can be dimmed. For those you need a large diameter bit to cut the hole if you do a flush mount, otherwise they can be surface mounted.
Another source that I have never used is TASK Lighting at http://www.tasklighting.com/.
The only complaint that I have heard about under cabinet lighting is that one can get a big reflection off of shiny solid surface or granite countertops. This has never been a problem in our kitchen as the countertops are usually so junked up that no reflection could be seen even if there was one :) .
Hope this helps.
Jim
Clint Searl
Clint Searl
I used a combination of Halogen and Xenon on a dimmer transformer. Lot of light and the dimmer controls intensity. If I did it again, I'd use all Xenon or LED. Don't know if the LED's can be on a dimmer.
Clint
Howard Norman
There are dimmers for LED lights but I am not sure if they will work with a standard dimmer or not. My guess is that they won't.
David Barnett
Dimmable LED bulbs (short video) *LINK*
David Barnett
Some composite LED bulbs will dim with standard switch dimmers. Others use special dimming circuits. White LED lighting has come a long way in a very short time.
Note that unlike incandescent bulbs, the color temperature remains stable when LEDs are dimmed. Only the brightness shifts -- a real advantage for task lighting. The exception is a hybrid using two sets of different color temperature LEDs to simulate incandescent dimming, but I don't believe these have hit the market.
LED 'bulbs' with standard dimmers
We used T8 fluorescent fixtures, and wired for them while the walls were open (positioning the BX cable at the right height and location for the cabinets was scary, but worked out). You can get warm white T8 bulbs, although I had to order a whole case to get them from our local home center.
I love them. We have food prep areas to the right and left of the stove, and I switched them separately; on the other (sink, dishwasher, microwave) side, I have one switch, with fixtures with toggle switches.
I love the arrangement - we can turn on just what we need, they're bright but don't produce noticeable heat, and the T8 comes on instantly, doesn't buzz, and is generally so much better than the old T12 bulbs that there's no comparison.
We also have similar fixtures on top of the cabinets (no soffits) that bounce off the walls and ceiling. I was skeptical, but the amount of light produced is a delight. Our kitchen is trapped inside the house - the only windows are waaay down at one end of a long narrow kitchen - but the overhead lights make it feel like daylight inside, when we need them.
Re: Dimmable LED bulbs (short video)
Howard Norman
David, I looked at the link you posted and have bookmarked it. Like a lot of new technology LED lights have moved vary rapidly in just a few short years.
