String inlay on curved surface
frank ashmore
Im making a demilune cab.I want to do some inlay on the curved surfaces.I am using kerfcore bending board.Kerfcore is a particle board with an 8th in.thick poplar face side and a kerf every half in. on the other side ,its very bendy.My ? is can I vacuum press the face side flat ,then cut the recesses for the inlays?Then veneer the inside of the it on the form I made in the vacuum press.Will this cause the face veneer to crack?So the stack will be a veneer face,the kerfcore,and then the inside face of veneer .Thanks
