200+ woodworking book reviews
window glazing repair
Rick Snyder
Hello,
A friend of mine brought over a palladium window/door from an old corner cabinet. He attemped(several years ago) to strip the paint off so he could stain the cabinet. He gave up after several attempts to get it off,so it's in my shop now. QUESTION... the inside of the window/door is glazed,so what is the quickest and most effective way to remove the glazing. The window/door has been sitting in a damp basement and has some mold,a broken pane, as well as missing glazing. The glazing is my biggest issue with this project.
Thank You,
Rick
Re: window glazing repair
ChrisF
The easiest way to remove glazing is with heat. I reglaze windows on my old house on a regular basis, and use a Wagner heat gun. It has adjustable heat settings, and comes with a "dustpan" shaped nozzle attachment which works great on glazing (the nozzle allows you to heat up the glazing while simultaneously shielding the glass from the heat, which can crack it).
Warm up the glazing, and scrape it away with a dull chisel. If he wants the paint off, the heat and a 5-in-1 tool and a good paint scraper will make short work of it.
Do take necessary precautions if there's a chance that the paint has lead in it. Do it outside if possible, wear a proper HEPA respirator, be sure not to set the temperature of the gun so high that it atomizes the lead, and collect the old paint chips and dispose of them properly.
