Cordless Elec Chainsaws again
Robert R. Clough
Because of the post below I became intrigued with looking at, and perhaps purchassng, a cordless electric chainsaw. I say cordless as most of its use would be beyond a 100' cord. I also do not need an expensive one and want about a 10" bar.
I agree Sears elec saws are Remington. I went to Sears to look at one. Lo and behold, Sears does not stock the cordless at all and does not plan to, according to the salesman I talked to. How stupid!
I checked at Elliotts Ace. They have the Black and Decker cordless at about $109 but I don't quite trust B&D.
Home Depot apparently has little of interest.
I cannot find local Remington Dealers. I will not purchase online w/o actually handling the product.
Suggestions?
Re: Cordless Elec Chainsaws again
Tom Dunlap
There is a proper cordless chainsaw being developed in Europe. Not on the market yet.
Running a chain takes LOTS of power. Too battery draining right now.
A cordless recip saw with a super coarse blade may be a better solution.
Kneale Brownson
Kneale Brownson
Agree that a cordless recip with a long wood blade would be a better selection (and wider range of uses) than the short chainsaw. I recently used a Rigid cordless recip to cut easily through 4X4 material and then switched to a metal cutting blade to use as a power hacksaw. Made both tasks easy.
Robert R. Clough
I already have a recip saw, corded, that I seldom use. I have little use for a recip.
Howard Norman
I find my Milwaukee reciprocating saw to be one of my most used tools for general homeowner usage. I first purchased it as a pruning saw for cactus. It has been used for many purposed over the years. The last major use was to cut plastic culverts for drains under the road. It certainly isn't a furniture building tool but for general cutting I consider it a great purchase.
Obviously your mileage may vary.
Buy one but they're a waste of money
Tom Dunlap
If you're determined to buy a cordless chainsaw, have at it. But...they are one of the tools made that are a waste of resources. They're cheaply made so they have a short useful life before they break. The parts, if you can find them, are prohibitively expensive...and...the saws have almost no power.
I'm an arborist, I make my living owning chainsaws so I pay attention to them. The electric one that I have is a Sears, made probably fifteen years ago and is pretty solid. Even the corded ones these days are almost worthless unless you buy a name brand.
I've used my DW 18v recip for pruning jobs when a chainsaw or handsaw wouldn't work.
Robert R. Clough
I do no cutting as you describe. I use my recip primarily as a power hacksaw.
Rick L
Re: Waste of money...
Rick L
The cordless recip saw is a much better option and you can get pruning blades for it. Since you already have a corded recip consider a power inverter to work off you vehicle or lawn tractor or if those aren't an option a small generator. There's always the Gomboy pruning saw which cordless and arm powered. Very good saws!!!
Thnk you but none of you .  .
Robert R. Clough
has answered my question and have answered a question I did not ask.
Therefore I shall physically trek to various stores to check, lift, and handle any such saws as I may find.
I am nearly 80 yo and find a hand pruning saw very hard to use. Because of extreme Asthma I have little stamina even with Oxy and must stop often when doing yard hand work.
I do not like recip saws. I find them hard to use. I much prefer a single direction blade.
I now find a gas CS heavier than I like although I do have and use a Stihl.
I do not use a CS more than a few times a year. We have 2 1/2 acres largely woods (and dead, now, Rock Elms which tend to fall just where they're not wanted).
Cordless CSs may be "junk" to an Arborist, but I am not an Arborist. We would use such a CS along with the Stihl to cut up 4" to 12" dead Elms and bushes a few times a year.
Re: Thnk you but none of you .  .
Howard Norman
Robert, I went back and read your original post. If you are set on handling the product before purchasing and you insist on a cordless chain saw the only option that i see that you have not explored is to travel to another town to find a saw that will be satisfactory to you.
Stihl at one time made a small battery operated chain saw on the end of a pole for pruning if my memory serves me correctly. I never used or saw the saw but it was on the web site at one time as I recall.
I am 76 years old so can relate to the physical limitations that you mention.
You asked for "Suggestions?" ...
John E in SC
Seems to me like that's what you got.
Good luck with your search.
Mark Nowicki
Ryobi makes a cordless chain saw with a 10" bar.
The product number is P542. The battery is an 18V lithium, it is one of the tools available in the Ryobi OnePlus+ system.
If Home Depot does not stock it they should be able to order it.
Perhaps I am reading it wrong, but it sounds like you can't find what you want, and you want others to do it for you.
Mark
Robert R. Clough
No, I prefer to do "web work" first before actually traveling - and many stores, Sears for example, have two distinct lines, one for web and online sales, and a much less complete line in store.
I did go to Home Depot and found the Ryobi. It balances well and Ryobi has a decent reputation for quality. I also found Black & Decker at Elliotts Ace. It has poor balance and therefore would be tiring to use, even for a short time.
Ryobi - I have one
Hoa in Alameda
I have one - Ryobi 18V cordless chainsaw. It was brand new when given to me by my then nextdoor neighbor when he moved away.
I tried to use it - once - to shorten a Christmas tree. The diameter of the trunk was about 5" - 6". I finally got frustrated and used a handsaw to finish the job. That was about 6 years ago.
It has been sitting on a storage shelf above my garage door ever since.
Robert, it's yours if you can arrange picking up or shipping.
Big dif. btwn. junk and poor quality *LINK*
Tom Dunlap
The elec. chain saws and the Ryobi cordless aren't necessarily junk but they ARE a waste of resources. Since I make a living using chainsaws I keep up on what is out there.
I think that Hoa said a lot without saying much about how the Ryobi works.
Chainsaws have been called the most constructive and destructive tools that man has made. I bet that the medical bills from chainsaws is higher than table saws.
Along with any chainsaw there are some safety gear that should be purchased. Helmet, ear protection, cut resistant pants or chaps. Even though you may not be doing this on the job, the saw doesn't know the difference. Chainsaw cuts are THE worst...ask someone in the ER or in rehab.
Recips may not be your fav but they are MUCH safer. My Dad gave me back his gas chainsaw when we was in his late 60's. It was too heavy and a bother with the oil/gas etc. Even his crappy Wen electric chainsaw was a bit awkward in his early 70's.
Be careful using chainsaws. The average chainsaw injury requires 110 stitches! When does stitching become sewing?
http://edis.ifas.ufl.edu/ae186
Chainsaw injury stats
Rick L
Re: It's up to you to give info
Rick L
so the answers are more geared toward your questions. I see this time and time again on posts. What someone asks for is rarely what they need. Your age and abilities and needs are certainly an issue. That certainly can changer the answers.
Ryobi, batteries and chargers additional expense but reasonable
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&productId=202042149&langId=-1&catalogId=10053&ci_sku=202042149&ci_src=14110944&cm_mmc=shopping-_-googlebase-_-D28X-_-202042149&locStoreNum=8452&marketID=272
Re: Big dif. btwn. junk and poor quality
Wade
Just another thought with a slightly different direction. With that size property, I am guessing you already have a lawn tractor with a trailer or something that you are using to haul your wood. So how about picking up a small Honda generator and one of these Stihl electric chainsaws (http://www.stihlusa.com/chainsaws/electric.html). The saw is better made then anything that I have seen in battery chainsaw's, and will probably outlast most of us with just a little regular maintenance.
Wade
