WE MOVED...
Dado blade set sharpening question.
After many years of use, I find that I need to sharpen my dado set - or at least some of it. Most notably the outer blades and a couple of the 1/8" blades. Some of the other blades have not seen much use (some haven't seen any).
With that in mind - should I just sharpen the blades that need it? Or should I have all of them sharpened? My thought was to insure that they all have a similar geometry. The cost to sharpen is $0.25/tooth.
Thoughts, opinions please.
TIA.
Re: Dado blade set sharpening question.
Moses Yoder
Moses Yoder
A dado blade set needs all the blades sharpened each time so that they are still the same radius. Sharpening removes a small amount of the tooth and the ones that aren't sharpened will be higher, causing an uneven groove.
Jesse Cloud
Moses nailed it. Sorry.
I had that feeling.
So it will be a few dollars extra.
Re: I had that feeling.
Joseph Mulherin, Sr
JL, as compared to having the blades sharpened or buying an entirely new set of blade set....what might be the difference??
FredD
The standard way to grind Dado blades is to sharpen them all each time and the inside chippers ground 1/64th of a inch shorter then the outside blades.
That is the configuration when they were new and results in a tiny groove on each side of the cut.
FredD
Outers - 2 blades at 30 teeth each = $15.
Chippers - 4-6 teeth on 12 blades = ~$15.
Total - $30. New set of dado blades $60-120.
I think I would rather have them sharpened :D.
Dale Lenz
You can request...
Dale Lenz
a "totally" flat bottom cut, at least from Forrest. When I ordered my Forrest dado set I had them grind the outside blades the same as the inside cutters, as my splines on my flag cases show and wanted the sharpest looking spines or keys as I could get. After hundred to thousand of splines, I'm glad I chose the flat bottom grind, even if 15 thousand isn't much, don't have a glue escape problem.
