Finishing - Proofread
Pat,
To get water-white (clear, non-darkening) finishing, you're looking for some of the new waterborne acrylic lacquers. They do have a tendency to raise grain so an alcohol or fast solvent-based sealer will eliminate a lot of sanding on the first coat. When I want as little amber as possible, I seal with a 1.5lb cut of 100% dewaxed Ultra Pale shellac, followed by a quality waterborne like Target's Em-Tech or General Finishes' Enduro. If you don't want to go the mix-your-own route on the sealer, Zinsser's Seal Coat does a good job with very little coloring. You do want to stay away from the Big Box stuff like Poly-crylic [sp] as the films have diffraction ratios that push them into the cool blue range.
Of course, you can also go through the water grain-raising and resanding routine instead of the sealer, but I find I get much better grain "pop" with at least a spitcoat of shellac.
[I really hate it when I go back and read something I posted that looks like I typed with my feet. Sheesh!]
