We value your privacy.
Looking at rebuilding some batteries for 12 volt tools. Can get Nicad for $33 and NiMh for $45.
Which type would you prefer for a shop where they get used hard once in a while and then lay around for a week or maybe a month between uses. Doesn't one of them discharge on its own? These are for drills and impact driver.
I had my DeWalt 12V rebuilt with the NiMh cells. I was coninced that it would be a great swap based on all the stuff I read. Well, it hasn't worked out so well. I have a similar usage schedule to yours and the batteries are almost always dead and don't hold a charge. I may try out a lithium ion drill if I can get one during the Christmas sales. Lithium has a fairly specific life, but at least it might work better during that lifetime. I hate batteries! It really bothers me that my drill is just fine and it may get tossed becuase of the battery situation. I may just stay with my good old corded model and quit fiddling with the cordless. I don't use it outside of the shop that often anyway. My old DeWalt 3/8 corded is around 15 years old and it will twist your arm off!
I have the same usage schedule and I've grown to hate Ni Cads because they dribble away their charge while nobody's looking. I recently bought a set of Panasonic Lithium Ions (drill and impact driver). WOW! What a difference. They hold a charge a long time, even when they're sitting unused. I'm not looking forward to replacing the Li-Ions when they die, but they're sure nice users while the batteries last.
How bout doing that shorting out between the positive and negative contacts trick to get them to hold a charge again? On Youtube, it looks like it works pretty well.
I've read several good comment son the Panasonic. I'll have to take a look. Seems like I red they build for other folks too. I think they may make their own cells (there aren't but a few that make the cells). I work at a very large shipping company and we have a few hundred thousand lithium cells out in the field. Our rule of thumb is that they will live through around 400 cycles or about a year and a half in the field. Now, they die while stored, so that's an issue too (should be stored at 40% charge). And they don't just quit, they just lose capacity. Funny, as much as I hate batteries, I'm ont he list to buy a Nissan Leaf, which is a battery (well, lots of batteries) on wheels! Go figure.
here is a video on how to zap your battery's. This works I have done this many time's and a frend that has lot's of batter's . He is in construction and has lot's battery's. I went up to his place and did a doz or so They were dead. But i used two twelve volt car battery's in serries to get 24 volt. All you do is hook up the neg. and than flash with the pos. You don't conect it on the pos side you just ark it 3 or 4 time's than put it in the charger. It will be like new. The video show's a welder. But most people don't have a welder. Always use more battery voltage than the battery that you are flashing. Here is the link. But just sub the car battery's for the welder
what make you come to the conclusion it is backward. The red leed is comected to the black as a jumper. So the red leed is on the neg. side. The tip is pos. That is the way i see it. Why would you conect it backward's ?? To see what happen's ? Not a good idea
as they say on Myth Busters. I can't find words to adequately describe how dangerous and dumb this procedure is. Anybody that thinks some welder has found a better way to charge batteries than the people that invent batteries, could be ignorant enough to risk the consequences of this procedure. At least ensure that innocent bystanders are at a safe distance. Screwing around with charging a battery in a way other than what is intended is an excellent way to blow up a battery, sending toxic, corrosive or even pyrophoric material flying about.
There is an extraordinary amount of energy packed in a small battery package. Do something that compromises the components that keep the battery from spontaneously discharging and the results will be spectacular as this chemical energy is released as heat.
you are zaping the battery Not charging it. I have done this . Their is no danger in doing this. If you read my use of car battery's 2 of them for 24 volt that is enough voltage . Instead of a welder. Now welder sound's like a big bad thing. It isn't . You turn it down to the lowest voltage. Not having a electric welder. But all you are doing is flashing the battery. That's all. Not charging it. Than it would be danger in doing that. Exceading the charging voltage wouldn't be the thing to do. I have done this many time's and never had and problum's. Don't do it and blame me. Look at google and their are lot's more that describe lot's of different way's. They also sell on Amazon a battery zaper for cell phones and lot's of other battery's. Must be safe ????
On the Youtube video, the guy is hooking his welder up to the "positive" side of his drill battery and zapping the "negative side.
Is there a difference which way you hook it up when you use two batteries versus using a welder? Does it even matter which way it's hooked up as long as you only tap the opposite terminal a few times?
The reason I have never tried zapping my batteries is because it's confusing as to which way to hook it up. That's why I ask about what would happen if one were to hook it up backwards. Would it just not work or is there a danger in the thing blowing up? I know these might be stupid questions, but that's all a stupid person knows to ask.
What you are missing is welders (at least TIG/stick) "ground" is positive (the electrode is usually negatively charged), ie reverse of batteries. Messes with my mind when I use my TIG power supply for electrolysis. Another interesting factoid: TIG welders are constant current, MIG welders (like used in the zap video) are constant voltage.
I've been driving a Toyota Prius since early '05. I've got almost 100K miles on it with never even the tiniest problem. I don't know about the Leaf, but the Prius is a great little car. A while back, Toyota was claiming they have never had to replace the batteries in one of their cars. I don't know if that's still true, but mine are still going strong after almost six years.
