Need advice on veneer restoration
DouginDenver
I am trying to restore a wooden chess board my father bought my mother about 65 years ago. It is about 24" x 24" and the core is solid wood - probably maple. The top playing surface is veneered (as is the bottom). The top has a band around the edge of mahogany veneer maybe 1 1/2" wide. The squares of the playing surface are walnut and maple. The veneer is 1/32" thick. The squares are 1 3/4" square.
Here's the problem. About a third of the squares - almost all maple -have started to curl up along the edge parallel to the grain. Where they have curled up enough to be above the surface of the adjacent walnut square the fix is easy - put some glue under the edges and put it in the press. But most of them have not curled up nearly that much. There is glue failure only along the very edge, such that the lifting along the edge is almost imperceptible but will look really bad if I finish as is. Any attempt to lift the edges enough to get glue underneath will just break off a sliver of veneer. What can I do? My only thought was to squeege some yellow glue along the affected seams in hopes that a tiny amount would get underneath - just enough to hold once pressed. Better ideas?
Re: Need advice on veneer restoration
Couple ideas for you
You can work glue into cracks by simply laying a little bead along the crack and using your (clean) fingers like a squeegee, pressing and pushing as you drag your fingers over the crack at varying angles. You can also use compressed air to blow it into the cracks. When you're done, there should be enough glue in there that it squeezes out when you press down on the loose edges. Be sure to use wax paper when you press it.
FredD
A game board that old and veneered, was most likely with Hide Glue..
Sometimes appilcation of heat from a household iron will reactivate the glue enough for a bond.
If you do use new glue , I would reccomend using hide glue because it will bond to the old hide glue.
FredD
Second The Hide Glue
David Yoho
I was already thinking hide glue before reading Fred's reply. That would be my choice before yellow glue in this instance. My main reasoning is that if you clamp right away, the dry hide glue will be very easy to wipe away afterward with a sponge and warm water.
The liquid hide glue should also give you enough open time to do it all at once, add a piece of wax paper over it, and clamp. I would probably lay a piece of 3/4 plywood the size of the board over the wax paper and then apply whatever clamps you like.
