Spray gun
Spray gun
Spray gun
Robert R. Clough
Some time ago one of you suggested that the Harbor Freight spray gun, about, $75, was ok to use. Well I purchased one BUT the instructions are not quite useless regarding viscosity. There is a viscosity ball cup but I have no idea how to use it , nor have I any ides how thin the latex paint , or anything else for that matter, should be. I did e-mail HB but have had no answer. Of course I can muddle through and probably do ok, but . . . These are three needles and I suppose I should use the largest for latex.
Any suggestions?
Oh yes, the whole "package"appears to be the same as that sold by Rockler - at a much higher price.
Re: Spray gun
Jim Rahbe, Bedford Texas
Latex did not work for me...
Bob,
I assume you are talking about the self-contained HVLP unit. While it has worked great for me when shooting shellac and lacquer, it did not work at all when I tried to use it with latex paint. In order for it to atomize the paint, I had to thin it way too much for it to still be called �paint�. Mine only came with a total of two needles, so maybe that is why they now come with three.
The instructions say that the viscosity cup should empty in 8 to 20 seconds. I assume this means that if it takes longer than 20 seconds it is too thick to spray. I don�t use the cup, as I�ve never had a problem with shellac or lacquer not spraying.
It would not hurt to just experiment with thinning the paint and see what works. I only used water to thin the paint when I tried to use it for shooting latex. I suppose you could also try one of the paint conditioners made for airless sprayers, such as Floetrol.
Jim R.
Re: Spray gun
Re: Spray gun
Ken Bellock (Houston, TX)
I have a very similar HVLP gun, and I have shot latex with it on a couple of occasions. Use the largest needle. I thinned with floetral and water to get it to shoot. I did not measure or use the viscosity cup, I just kept adding till it shot well enough, and then mixed each following batch to approximately the same consistency. Just do what I did and grab a big piece of cardboard and experiment till you get it to shoot the way you want.
Hope you have a nice compressor, if your gun is like mine, it is a real air hog!
Re: Spray gun
Re: Spray gun
Joseph Mulherin, Sr
I found out many years ago that you can dilute latex paint for use in a spray gun. I use the old fashioned spray gun with the quart bottle screwed on to the spray nozzle. To dilute your paint to use in the gun just add one quart(1qt) of water to a gallon and stir every time you are going to add more paint to the gun bottle. And I set my compressor to 35lbs pressure. When spraying you will find that the paint starts to clog up on the nozzle tip...so just wear a cloth glove and swipe the nozzle off every so often. I repainted my entire outside of my house using this method about 4 times over the years and it always came out very well. When finished for the day of spraying you just have to washout the nozzle with warm water until it sprays clean and rinse the bottle out the same way.
Re: Spray gun
Re: Spray gun
Joe,
He's not using a compressor-driven gun. His setup is a turbine-driven HVLP that is unlikely to have a pressurized cup, so he's not going to get near the 35psi you mention to atomize that heavier coating. He'll need a conditioner like Floetrol and the largest cap/needle set he's got plus the viscosity cup check in order to get this gun to work latex.
Re: Spray gun
Re: Spray gun
Warren White
I have a Graco HVLP turbine, and have used it to spray latex. I thinned with water and used Flotrol (if that is how it is spelled). I have only used it to spray beadboard, crown moulding and baseboard, but it really came out fine.
As for the amount to thin, I have been told to dip something into the paint, let it drip off until the drips are just drops, and the drops come about one a second. I don't know where i got those instructions, but they work well for me.
Re: Spray gun
Using a viscosity cup
Michael Dresdner
The description above is correct; dip the cup into the liquid, lift it out and count the seconds until it is empty. Interpreting it is what is vague.
Simply put, a cup is a benchmarking tool. Take a material that sprays well through your spray gun, measure it with the cup and use that as your benchmark.
When you measure an unknown material, you will know, based on the cup drip time compared to your benchmark, whether or not it is likely to spray well. If it takes much longer to get through the cup, thin it. And yes, you should be thinning latex paint with Floetrol rather than water, as it contains a package of solvents more similar to the original group in the paint.
