Veritas - Innovation in Tools
Microwave mounting heighth
Scott in Phoenix
Hello all
What is the minimum distance between the cooktop and the bottom of a built in microwave?
TIA
Scott
Re: Microwave mounting heighth
Whatever the lowest level of the upper cabinets happens to be. Many people install upper cabinets at about 16-18" above the lower cabinet counter top.
If you are going to install a microwave above a range, your above range cabinet should be about 15-16" shorter to allow you to install a microwave. In the "olden days" - the above range cabinet was shortened to allow you to install an above range exhaust hood. This was typically 4-8". This brought the built microwave to about 10" above the cook top - which is WAY too close.
Now if you have some large stock pots - they are going to be 8-10" high. If you have some REALLY large stock pots - they might be on the order of 12-15" high. So you figure you want to have enough space to at least look into the stock pot and stir. If you don't have the really large stock pots, 18" above the range top should be okay.
Another way to figure it - your counter top would probably be 35-36" from floor level. This would put the bottom of the microwave at 52-54" above the floor.
Moses Yoder
Moses Yoder
Your cook top or stove and your microwave should both have specifications that you can look up on-line unless they are really old. If you do not mount your microwave according to spec the warranty will not cover damage to it. To look up specs online do a search for the brand name and model # on Google, they should pop right up; if you can't find them then post the name and # here and I will see if I can find them. I look up appliance specs every day.
John Veerkamp
Cabinet makers use 54" from the floor for "standard" height over either a stove or counter. For appearances having the bottom of the microwave the same as the bottom of the upper cabinets looks best.
Jim Dillon
Scott,
Check your installation instructions. I seem to recall mine said 18 inches minimum measured from the stove top. As both my wife and I are tall, I made it 20 inches and it seems to work fine.
Jim
I looked up clearances in the International Residential Code. To unprotected wood its 30" and to wood protected by a non combustible material its 24". (Vastly simplified). To appliances, its "according to eh manufacturer's directions." So read the instructions with the microwave or google them.
You have something of a conflict. Its desirable to raise the microwave to leave clearance for large pots and to help keep the heat off the unit, but its desirable to keep the microwave lower to have easy access for loading heavy things into it and so that they are easy to tend to, stir, and remove without dumping them on your head. So, you should install them as high as you can while keeping them low.
FredD
Barry is correct on the distance above a stove or cook top.
What he didn't mention and I am sure he knows is a Microwave mounted over a stove is a accident waiting to happen and a expensive one if the cooktop is Ceramic and you dropped a loaded Cassarole dish on it when you took it out of the Microwave.
FredD
FredD
The Federal Government suggested height from the floor to the bottom of a Microwave Oven for optimun ease for most people (read Ladies) and the one Cabinet Makers such as myself go by is 48 ".
I developed a way to install a Microwave at the request of a housewife client who wanted the countertop to run under the Oven in one continous top and "could I make it not stick out so far"?
So this is the way I have done it for years and Ladies love it , especially the five foot high ones like my wife.
This causes the Microwave to be fifty inches rather then 48 above the floor to keep as much height for storage under the Oven as possibile.
The installation in our Kitchen is about three years old and typical of the method I used before any Cabinet shop in CA did. Flush with the Cabinet face with a trim kit by Amana
http://picasaweb.google.com/lh/photo/7cS94qULLjrLpgGXNSQKa2Sp_AdJEPXskZCK3YtOYys?feat=directlink
FredD
Fred's right. That was apart of the point in my semi-humorous attempt describing the height. Over the range is not a good place for a microwave except that it gets it up and out of the way, off the countertop. A space saving feature. (weren't some of them called "space savers") The problem is that from a cooking perspective, its a terrible location unless you are really tall. If you can't conveniently see into the dish you might be tempted to tip the dish up to see into it and spill the potentially hot contents on yourself or the range. (Think of the permutations of hot stuff hitting the hot cook top.) And you could easily lose your grip on something and drop the whole pot on the range. If you actually cook anything more complicated than a cup of tea or a bag of popcorn in the microwave it would be much better and safer to have it at a lower level. And, if you do any serious cooking on the cook top, how easy is it to clean the under side of the microwave? I've seen them where the back burners are essentially useless. I suspect the location only looks good until you present it to a serious cook who has the option of choosing better designs. But, many of us do about as much take out as cooking these days.
OTOH, he did not ask if it was a good location, just what the clearance should be.
Jim Dillon
Scott,
I, perhaps mistakenly, assumed you were mounting a microwave INTENDED for using over a stove and has a built-in exhaust fan. I was able to find my old installation instructions for my GE Spacemaker and it says to position the TOP of the microwave 66 inches or more from the floor. Since the microwave is roughly 16 inches high, this would mean that the bottom of the microwave should be 14 inches or more from the top of a standard 36 inch high stove. While that height would sure make the exhaust fan work more efficiently, for me it was way too low. Thus I moved it up to the 20 inches I mentioned earlier.
I believe I have seen microwaves mounted above a separate exhaust fan, but that might put the microwave up too high and be less safe to use for the reasons mentioned by other posters.
I sure would be cautious about putting the microwave on a wooden shelf directly above the stove, no matter what the height because the potential for grease fires etc. And I would also be hesitant about wall-mounting a microwave intended for normal cabinet-top placement because the bottom may be open to accumulating grease which may lead to future problems.
One last thing. My microwave weighted 68 pounds. It is heavy and very awkward to mount; having two people sure helps. If you mount it to the wall, make sure it is mounted very well.
Jim
