Leveling shellac Question
I don't really enjoy finishing. that said, I have been using shellac on some projects. The problem is I have trouble getting it to level out or go on smoothly.
Whats necessary? Does one of the really expensive brushes make that much difference? Which one?
Anybody use one of those fuzzy pads?
A second question. When you use shellac as a sealer coat under some other type of finish, do you have to sand it or level it well. If you put a finish over a less than level shellac coat does it show up or does the top coat "appear" to level the shellac.
Re: Leveling shellac Question
Steve Schoene
Yes, the shellac has to be level since any problems will be telegraphed through the new finish.
First a few questions about how you are applying it. First, what pound cut are you using? What kind of brush? What specific variety of shellac?
Re: telegraph through? yes
Henry (Raleigh, NC)
To echo Steve's answer, what you see in a shellac coat is indeed telegraphed through the topcoat - at least in my case. I was using a 2 lb cut of shellac (at least that what i think SealCoat is straight form the can).
I recently brushed a satin lacquer topcoat over shellac on a table top. Since the lacquer label described the self leveling properties of lacquer, I was hoping for a magic cure-all to my finishing disabilities - and was quite disappointed. I expect that I will be stripping the lacquer and starting over.
Henry
I am using Zinsser Seal Coat Dewaxed Shellac Straight out of the can. And for a brush I am using a good quality sash brush.
Have not gotten into mixing my own shellac. Trying to figure out what is truly necessary to get a decent finish. As I mentioned, I am not "into" finishing. I would rather build two pieces and turn them over to somebody to finish them and they keep one of the pieces a payment.
What we were going to do is take this table to a friend who has a cabinet shop and let him finish it with Pre Cat Lacquer. The same Gilmer lacquer he uses on kitchen cabinets. (There have been other posts about this and conversations with both Deft And Gilmer about whether the two types of lacquer are compatible, so to be absolutely sure I told him to leave it bare, but he did not listen.) My hard headed son decided to speed things alone and put lacquer sanding sealer on it. My friend put us off a few days so my son decided that polyurethane would be a better finish than lacquer. And that he should put a barrier coat of Seal Coat on to be sure there were no problems. I told him I had not had good luck with this process and that the internal layers would show through. Again, he would not listen. So, now we have a table with two coats of lacquer sanding sealer, a coat of Seal coat and two coats of deft polyurethane. And, tho level them, he sanded them with a ROS. Now he is complaining that the internal layers are showing, but also has amnesia about the advice. What's a Dad to do?
So, my Questions are going back to square one. What's the best brushed on finish for a table top. And What is truly necessary to do a good job with Shellac?
answers
Bill Tindall, East TN
I don't really enjoy finishing.********when you get good at it it will become a joyous event. Getting good involves practice and a spray gun helps get good quicker. The problem is I have trouble getting it to level out or go on smoothly.*****very common problem
Does one of the really expensive brushes make that much difference?***not essential Whats necessary? proper training This past year I have gotten to watch two professionals apply shellac. Both had two things in common...namely using about a 1.5 pound cut, and, they moved the brush rapidly over the area. In one case the person used a brush that held bunches of shellac and they took long rapid strokes to cover an area. In the other case the person used a Takalon artist brush that held almost nothing and the applied the shellac with rapid short strokes and frequent rapid dipping into the reservoir of shellac. There is no way I could describe either technique in sufficient detail for you to successfully repeat it. But in both cases with their tutelage I was able to apply an excellent finish to a panel, nearly as good a finish as I can apply with a spray gun. (There is a good reason cars are spray painted to get them perfectly smooth) The third technique I have seen is to apply with a pad wet with about 0.5 to 1 pound shellac. It takes forever to build a coating with this dilute material. .
Anybody use one of those fuzzy pads? No, but a piece of foam works admirably.
A second question. When you use shellac as a sealer coat under some other type of finish, do you have to sand it or level it well. Yes definitly. It sands easily.
A third method
Dave Bair, Eaton Rapids, MI
For large surfaces, I've had problems with shellac related to leveling; I can't get it on fast enough to prevent build-up where I overlap brush strokes. After a lot of trial and error, I came up with the following:
Cut the Sealcoat to a 1-lb cut using 90% isopropyl alcohol,
Apply a coat using a 4", white foam roller (there will be tiny bubbles),
Quickly brush the shellac out using a wide, fine (flagged) synthetic bristle brush. Use just the tips of the bristles; you're not trying to level, just get rid of the bubbles by "pulling" them off the edge of the piece. The shellac will then level out the brush strokes by itself. Don't work the surface like we do with poly, just use one or two passes over an area. If the brush picks up too much shellac, blot the bristles with a paper towel and get right back at the bubbles.
David Hay Denver
One of the things I've learned over the years, which took me a while to appreciate, is that some amount of sanding of the finish, is usually required to get a smooth surface after brushing (I understand that spraying is a whole other ball game).
When I'm working with shellac, I typically thin it to a 1 or 2 pound cut for the first coat or two, as it's easier to work with. IIRC, the Zissner stuff is a 3 pound cut right out of the can, but has instructions on how to thin it. After each coat, a very light sanding is necessary in order to keep the surface mostly level and to knock down any high spots (be careful around those edges!)
After applying the final coat, you'll want to level the finish with 400 grit sandpaper, working up to 600 grit or higher, finishing up with steel wool possibly using some wax as a lubricant.
David
