Replacement height adjustment for drum sander
doug f, san clemente, ca
Some time back I came across an article on a homemade replacement for the adjustment mechanism for the Jet 22-44 drum sander. It involved a spring and a couple washers and eliminated the bit of slop in the OEM height adjustment knob that makes it so hard to get the drum parallel to the table. I printed it out and put it in a safe place to use when I needed it.
OK, I'm getting old; I can't remember where I put it and I can't find it after several searches on the Web. :\
Does anyone remember the article and where I might find it?
Any help would be appreciated.
Doug
Re: Replacement height adjustment for drum sander
Dave Paine
I do not know the article, but I do recall reading some other article about the Performax drum sanders.
I have the 16/32.
The item which caught my attention was replacing the spring and single regular nut with two lock nuts. The spring alone does not hold the drum at the desired elevation. The two lock nuts without a spring do a much better job.
I replaced my nut and spring with two lock nuts (without the spring) and found this to be more stable.
You will still need to try to calibrate the drum to be parallel to the plate. Easier said than done. The two lock nuts do assist in the delicate adjustments.
The lock nuts are the kind with plastic collars at the top.
I hope this helps.
Exactly what I was looking for!  Thanks.
