I have T8 fixtures in my shop - they interfere
with the FM signal upstairs. Yes, the signal is weak. They are the 4' fixtures that fit in suspended ceilings. The 2 x 2' fixtures in the other part of the basement do NOT interfere with the FM signal.
Yes, the radio is right above the shop - but it does it for every radio in the house.
So - I can change the ballasts. OK - which ballasts do I look for and what are some possible sources.
Would a RFI line filter work? If so, where can I get a couple?
TIA
Re: I have T8 fixtures in my shop - they interfere
JoeW in Detroit, MI
Check the current ballasts that you have in the fixtures to see if they are electronic. Older style ballasts were magnetic and used magnets and coils - they buzz a lot. The newer electronic ballasts are smaller and much lighter in weight and quieter. Are the lights and your radio on the same circuit? If they are you may want to explore moving the the lights to a different circuit if possible. Sometimes a cheap fixture is not a bargain. I've had some inexpensive shop lights that were horrible and the cost to change the ballasat was more than the price of the cheap fixture.
The probem is the electronic ballasts
bill tindall
As has been reported here before some electronic ballasts emit a signal that wipes out TV and/or radio. I have one in the kitchen that trashes just channel 5. Well that is the cause of the problem. I hope someone has the cure.
Re:Looooong reply, ......
Bob Entwisle in NJ
Ok,
DISCLAIMER: I am not a licensed electrician, and unless you are, I do not recommend you do any of this stuff yourself.
I deal with various sorts of noise in electronic systems on almost a daily basis. The information below is meant to help you track down and identify the source of your problem.
First,
I refer to "Noise" as what is causing a degradation of the audio signal that you hear from the radio. You may perceive it as a weak station, or as actual audible noise from the radio, but that is neither here nor there, the problem is that something is degrading the signal that you hear from the radio and that is "Noise".
Things to check for both radiated and conducted noise, (more about that in a minute).
If you have the lights controlled by more than one switch, does one or the other set of lights cause the problem? It could be just one bad ballast.
Have the integrity of the ground at the service entrance, as well as the integrity of the chassis grounds at each fixture, and of the components within each fixture, verified. Bad grounds can be the root of both conducted and radiated noise problems.
Is the noise radiated or conducted?
Simple test, place a battery powered radio in the same location as the line powered radio. Is the battery radio affected the same way as the line powered radio?
If the battery powered radio does not exhibit the nose problem, then the noise is Conducted, meaning the lights are sending noise to the radio via the house wiring.
For Conducted noise, a common mode filter at the radios AC input may eliminate the problem. Radio Shack may have something, I'm not sure. Post (or PM me), if you need to find a filter and I can probably find a source for you.
If the noise is the same in the battery powered radio, then it is Radiated Noise, (the lights are broadcasting the noise 'through the air" to the radio's antenna.)
A stronger signal to the radio via a cable or external antenna hook up could solve the problem, (probably cheaper than replacing all the ballasts if it turns out that 'all' the ballasts are causing the problem.
There are a lot of possibilities here, the idea I'm trying to get across is to attempt to isolate the problem somewhat, then you can know better what needs to be fixed. this is a 'deep' subject in the electronics field (meaning there's plenty of highfalutin' theoretical stuff, as well as lots of practical "in the field solutions").
Hope this helps
Bob in NJ
It is "radiated" noise. A battery powered radio (just about anywhere in the house) exhibits the same noise.
The noise is most prominent on the weaker signal stations. We listen to a "rebroadcast" transmittal of NPR most of the time. The signal is weak (hey - we're in the mountains). The local FM station has noise - but much less.
I reckon I'll have to invest in some new ballasts.
Clint Searl
Not to worry; it's only temporary
Clint Searl
It's coming from the cheap ballasts in the $20 fixtures, and as they start failing and have to be replaced with $25 ballasts, the interference will diminish until all of them have been replaced.
Clint
not necesssarily so
bill tindall
the worst interference I have is from a quality ballast I got at the electrical supply store. It powers a 4 tube 2' fixture and wipes out Channel 5 all over the house. As I recall from a previous discussion on this topic one can specify electronic ballasts that are designed to not interfere. On the other hand I have bought off the shelf replacement ballasts and some interfere and others don't.
Clint Searl
I guess I got lucky
Clint Searl
The $20-$25 replacement ballasts for 2/3 tube 4ft T8 fixtures from Lowes and HD have cured the interference.
Clint
FredD
Good post Bob and easy to understand
FredD
