Jointer identification
HapaJeff
HapaJeff
I've come across a jointer for sale. It's listed as a Yates, 8X70" or 72"; however, I can't seem to confirm that it is indeed an 8" jointer. Unfortunately, it's located 100 miles from me, so I can't just swing by the fellow's place to take a look at it. I'd like to do as much research ahead of time as is possible.
I looked in the photo index at Old Woodworking Machines (OWWM.com), and couldn't find a similar jointer. This jointer does look very similar to some of the Yates 12" jointers listed, though, but the owner maintains that it's an 8" model. Likewise, I also looked through some of the reprinted manufacturer's catalogs on owwm.com, but quite frankly, there were just too many to go through.
Any ideas about this jointer? Sorry for the fuzzy photos.
-Jeff
Re: Jointer identification
Dale Lenz
Dale Lenz
Have the owner send you a pic of the cutter head with a tape going length wise, the cutter head/knives should be 8" in length.
Good luck
Steve Schoene
The owner is never going to mistake a 12" jointer for an 8". "Mistakes" are always in the other direction, and it surely isn't a 6".
FredD
Yates-American are great machines,but every one I have seen or used was 3 Phase, might not be problem for you .
FredD
Re: Jointer identification *LINK*
Phil Smith
Looks very much like a Yates American based on guard and base. Here is link to picture of 8" American Jointer. P. B. Yates and American combined to form Yates American in the 20's.
Here is link to the 1930 Yates American Catalogue. The Yates American No. 1 is on page 18. Looks like the jointer in your picture is very similar particularly the guard.
http://owwm.com/pubs/detail.aspx?id=1433
Yates American made particularly fine machinery. Once you own a Yates all of the modern Delta's, Jets, etc. will look like light wt. toys. They list the wt. of the 8" jointer at around 1300 lbs. For reference a modern Jet 8" is just over 400 lbs.
Based on the picture that you posted it is clearly not a 12" jointer. Not big enough for a 12" Yates. A 12" Yates really is massive.
Picture of 8" American jointer
