Support Beam Calculator ?
Yonak
I'm having a carport built and I would like to independently find out how large a beam I need to support the roof over a 24 foot span. Is there a calculator that can help me figure the weight of the roof and the size of beam needed ?
Re: Support Beam Calculator ?
FredD
I don't know where you live , but California which pretty much is in the lead on Structural requirements, requires a Structural Engineer to sign off on spans over 24 feet.
Span table books should be available in your library , certainly in the Building Dept.
FredD
Clint Searl
Clint Searl
The folks who make beams and trusses have load specs.
Clint
Joseph Mulherin, Sr
Yonuk, try this website for some calculations you might be able to make:
www.engineeringtoolbox.com
The minimum section modulus of your beam will depend on the span, the total weight (live and dead loads), how and where the weight is distributed over the beam, the species of wood, its modulus of elasticity and fiber stress in bending, the allowable deflection, plus any safety factor or aesthetic consideration you might want to add to the equation. Back when I was running these calculations on a regular basis, I found the information I needed in a book called "From the Ground Up," a DIY shelter manual published in 1976.
Regardless of who figures out your beams for you, you'll have to have the plans approved by your municipality's code officer before you can build.
Richard McComas
http://courses.cit.cornell.edu/arch264/calculators/example8.1/index.html
