Latest Project - Treadmill Desk
Bartstar
Here is my latest creation - A treadmill desk.
Its really a prototype as I expect to get requests from others to build them a similar desk. I made it from rough sawn Catalpa - which is very light wood (similar to pine) and quick an dirty pocket hole construction.
One reason for using such a light wood is that I wanted it to be easy to move out of the way when not being used. On the other had, it may also make it a little less stable. We will see how it works in practice.
Both my wife and I work from home and spend way to much of our day sitting. So, I built this treadmill desk that will allow us to use our laptops and phone while walking at a slow pace.
I just completed it yesterday - and will start using it this coming work week.
One side note - this was my first time using water based finishes. I used General Finishes Water Based Poly, applied with a foam brush. The first coat caused major grain raising, and I had alot of hand sanding to do. 2nd coat cause very minimal grain raising and was fairly quick to sand. 3rd and 4th coats had no gain raising and went on quickly. Not bad stuff, once you get past the grain raising issues.
Thanks
Bart
Re: Latest Project - Treadmill Desk
George Colonel's Workshop-Havertown PA
Good Morning Bart,
That is an interesting application, and I like the looks of it very much. I sure wish I had had one of those things in front of me the last time I took a mechanical stress test! a standing desk isn't a far afield idea to begin with.
When I was working, I spent much of my time on my feet in front of my desk, especially when on the telephone. I would have welcomed your innovation, as my civilian job was a gigantic treadmill in its own right. Nice job.
George
Kneale Brownson
Hemmingway wrote at a stand-up desk
Kneale Brownson
Personally, whenever I'm on a treadmill, I get a little too sweaty to be handling a laptop.
WB Finishes
David Yoho
That desk reminded me of a picture I saw once of a massive computer desk that housed about six to eight monitors and had a panel in the base that opened. Inside was a treadmill and after slipping in a few railings the user could walk on the treadmill and adjust the desktop angle for easy viewing.
Anyway - I think you'll find that General Finishes is making some of the best water-based stains, dyes, and topcoats today. I know a pro furniture maker that swears by them.
Next time you might try raising the grain and sanding before applying your WB finish. Should the topcoat raise it any, at least it will not be as much to sand at that point.
I Quite Agree Kneale
Laptops are generally more applicable to swimming pools, unless you swim underwater. :D
George
That's because he was a stand-up guy
and I'm disappointed that the Colonel missed this obvious bird, just sitting there in the field, waiting to be caught.
Now, put a generator on it...
and you can power your laptop from the treadmill.
Dave Paine
Looks good.
As you experienced water based finishes can raise the grain. I use a sealer first which is a very diluted oil based finish. Quick to apply, quick to dry and no raising of the grain. I also use if I am staining so I can get uniform colour of the stain, especially on end grain.
The engineer in me says the height of this shallow desk will be very easily tipped. Consider some horizontal bars attached on the bottom sides to move the potential fulcrum back a foot or so.
I made a foot stool which suffered from tipping and this was only 12 - 15 in high. Needed horizontal bars to prevent tipping.
Bartstar
Great advice on 2 fronts; some questions:
Originally, I was considering using a sealer like Zinsser's Sealcoat, but when I experimented with the Finish on some scraps, I did not see as much grain raising so did not use it. However, the results on my actual project were very different. Perhaps cause the desk was sanded to a finer grit than my test piece?
Can you please be a little more specific on the recipe you use for your sealer?
I would be interested in trying that.
I share your concerned about the stability of a top heavy desk like this. I may try using some some small bungee cords to tie the legs to the treadmill if it ends up being an issue
Thanks Much
Bart
What a Green Idea!
Bartstar
Re: Hemmingway wrote at a stand-up desk
Bartstar
The concept of a Treadmill desk is not mine or new. Steelcase makes an all-in-one for several thousand dollars. Since I already had a decent treadmill, I just needed to add the desk part and at a cost of under a $100.00 in raw materials.
The idea is not to walk fast enough to break a sweat. You walk slowly on it - like 1 mile an hour. This way you are just moving a little and can easily type while walking this slow. The health benefits to slow walking versus sitting for hours a day can be very substantial over time.
Regards
Bart
Dave Paine
Zinsser make good products. I like their Shellac spray. Makes the grain stand out and can be a sealer if you would be using oil based finish. Zinsser claim it can be top coated with interior paints and finishes, but do not specifically state water based. Traditional shellac will discolour with water.
I have not tried making my own sealer, although many people do. Try a Google search.
I use Minwax Stain Pre-Conditioner. Looks like mostly solvent.
You could buy small can and try mixing your own solvent and oil based poly to see what ratio matches the consistency.
I am not surprised if your test piece was not sanded. Hard to deternine raised grain vs original rough grain prior to sanding.
Avoiding Raised Grain
David Yoho
There's any number of ways to get to the top coat step and not have it raise the grain. A lot depends on what products you'll be using during the finishing process.
In finishing tiger maple, I've used WB dyes before applying oil based varnish. With the method I use, the first application of WB dye is called a "trace" coat. It's function is to color the figure, raise the grain, and will spotlight any glue residue and sanding scratches that were missed. This coat gets sanded off but allows the color to remain in the figure, knocks down the fuzz, and corrects sanding scratch issues. Then a second application of dye (a different color but what I want the outcome to be) is applied. My experience has been that the grain does not raise again or, if so, very little and can be knocked down with a light hand sanding with fine paper. After all, I don't want to affect the final color by sanding at this point. This is followed by the top coat that dries smooth enough for 600-grit to take care of any dust nibs.
Probably the easiest way to handle grain raising if you plan to use WB finish (whether part or all) before switching to your final grit for sanding is to wipe down the surfaces with a wet rag and let dry. Then proceed with your final grit and sand. You shouldn't see much grain raising beyond the stuff you just sanded and this can cut out the need for a sealer coat altogether.
David
But What Will It Do To Commodity Prices?
Gettin' Corny, George!
S'wheat
David Yoho
