Shaper cutters question
paul in AZ
New to me is a shaper with 1/2", 3/4" spindles and 1/4 and 1/2" router collets. I want to use 3/4" bore shaper cutters and find the cutterheads with blade inserts an economically attractive idea.
Anyone with experience with some of the more reasonably priced head/insert sets like Amana? Other options?
Once you buy an insert head are you restricted to blades made specifically for that system or are the cutters generic?
Any thoughts on Grizzly's shaper cutters?
I will not be doing heavy duty shaping and expect that it will get moderate but infrequent use.
So far I've tested a router bit on hickory with wonderful results both with and across the grain so am satisfied that router bits do work at the lower RPM. I'd still like to go to shaper cutters.
I'm not asking for opinions on router vs shaper and all that. I've gone that route. This started with pricing out a good router table, lift, & bigger router. A semi-virgin, used 1.5 HP Jet was a screaming buy in comparison. Lest anyone feel offended, if Italians can have extra virgin olive oil I can use semi-virgin to describe a virtually new and lightly used shaper.
