I DISLIKE stripping paint.
It is messy. The residue is gummy. I would almost rather make a new set of cabinet doors - except that all the doors are different sizes.
Finally, it takes up valuable workbench space. Sigh. It will be over soon and I'll have my shop back.
I have discovered a good use for sawdust and wood chips though. I was "gumming" up far too many abrasive pads. I decided to try a handful of stuff from my dust collector. Lo and behold - it works quite nicely. It peels the paint and stripper off reasonably well.
Re: I DISLIKE stripping paint.
AMEN, Brother ! Hang in there !
steve mackay
FredD
Hardwood shavings are very useful in stripping a carved area.
FredD
Ditto
Gary Hodgin
Been There - Done That
David Yoho
JL, as one that sees many refinishing jobs, I have to say stripping paint is the pits. Especially many layers. I just go at it until it's all gone. I use a very strong semi-paste stripper, stiff blade putty knife, and coarse 3M-like pads. The wood shavings trick is an old one used for years and is a good use of shavings and saw dust.
Hang in there!
Re: Been There - Done That
Tom MacGregor
With proper ventilation and an organic vapor respirator (for lead & etc., working outside is best) I often carefully use a heat gun and scraper to soften and remove heavy layers of paint. It minimizes the amount of chemicals and goo involved. The value of the piece & whether or not its veneered must be taken into consideration, but heat can be useful.
Spence
Spence
Back in the day when I did refinishing for a living I used burlap and small brass brushes for the nooks and crannies. Back then a roll of burlap that was used for a ground cover only cost a few bucks at the local Agway. Worked really well. Not sure if it would be cost effective these days though. Thankfully my stripping days are over. ;)
