We value your privacy.
I have a teak patio chair whose seat bottom broke off from the leg. Upon looking at the damaged section, I noticed that the tenon had rotted apart, it was like sawdust, from the mortise joint. Is there a way to repair this?
Depending on how far into the stock the rot has extended, you might be able to make a loose tenon - separate piece of wood (of some weather-durable species) that is mortised into the rail and then into the mortise in the leg.
Or track down some teak and make a new rail.
Look closely at the mortise - if the tenon rotted, the mortise may be affected, too. Rot usually travels long grain before it goes side grain, so look especially closely at the top and bottom of the mortise.
It doesn't sound like it was really teak. It doesn't rot like that, unless it was sapwood.
If it is really worth fixing, I would normally cut on down the leg with a long scarf joint, then make a new part that can slip up into the mortise, while providing a long glue-line down the leg.
Epoxy would be my glue choice. You can make the tenon smaller to allow it to come in at an angle, then mix it up with enough filler to make it as thick as peanut butter to fill the space.
If you purchased this set at one of the big box stores, odds are slim to none that there is any teak in it. Teak would not rot in the weather in a two year period. Keith and Bill have some good suggestions for fixing it.
When you're done, I'd consider giving everything a couple/three coats of marine spar varnish, and then one more coat every year if you want to keep this furniture from rotting away.
On the other hand if the store where you bought it advertised it as Teak or genuine Teak or just like Teak , thne you would be entilted to either a replacement of the Furniture with real Teak or your money back at least.
if your in the market for a "solid brass bed" it pays to take a magnet with you.
