We value your privacy.
Has anyone here tried the vacuum/pressure-treating dye process?
Seems like I could rig up a 2" pipe "chamber" fairly easily, then mix a half gallon of alcohol black dye and hook'er up to my vacuum pump to get full penetration.
You pull a hard vacuum on the chamber, seal it, then let it suck in the dye from a second port, let sit an hour, pressurize the chamber to 90psi or so, let sit an hour, lastly bleed the pressure. If you don't continuously pull the vacuum, you avoid the dye solvent (water or alcohol) "boil".
"Has anyone here tried the vacuum/pressure-treating dye process?"
Personally or professionally? Yes, I did it for a couple of years in a company that I used to work for. We would draw a vacuum on the wood and hold it under vacuum for a period of time - this was to get rid of residual moisture and volatiles. We would do a nitrogen purge and hold. We would then draw a second vacuum. We would then let in the dye liquor and put pressure on the liquor tank.
I suppose you could just pressurize the vessel if your wood was beneath the surface. The process worked quite well for us. We used aluminum "boxes". I wouldn't want to use galvanized and I would be leery of using PVC.
We were working with some reactive chemicals to "lock" the dye into the wood fibers. We needed a nitrogen purge after the initial vacuum to insure that the water was completely gone.
As you aren't working with reactive chemicals, you won't probably need a nitrogen purge. I would leave it under a vacuum for a period of time though. It couldn't hurt.
My bet is that its purpose is to purge oxygen from the system before introduction of the flammable liquid. An industrial process is not going to want a mixture of flammable vapors and oxygen in a container if it can be avoided.
