Ebonizer
Ebonizer
Ebonizer
Thinking about ebonizing some walnut to use in glued-up legs, but wondering about penetration of the color. The legs, incorporating two 1/4" thick elements, will be glued up then tapered so that the original edges of the walnut will be cut away. Thus I'm looking for 100% penetration of the color.
I can do iron acetate or alcohol dye, but unsure about the penetration through 1/4" thickness.
Suggestions?
Re: Ebonizer
Re: Ebonizer
Stuart Johnson
Mark, I don't think you will get anywhere near 1/4" penetration. I've never actually measured it but I'd be surprised if it would be much more than 1/64".
Re: Ebonizer
Re: Ebonizer
So you're telling me to take the wallet out of the vault and go buy some Wenge or [gulp] Ebony, right?
Re: Ebonizer
Re: Ebonizer
Galen Vetterick
Mark
Maybe I do not understand but why dye the wood before shaping?
Re: Ebonizer
Re: Ebenezer
Mark, I think Stuart is correct. My limited experience with ebenezer treatment is that it has very shallow penetration. It can easily be sanded away.
I see that you want to taper the legs. Could you cut a slot after the legs are tapered and then inlay apiece of ebony/wenge/black wood. Perhaps even veneer? Are they tapered on a TS or lathe?
You could also taper them and then try to ebonize the edge of the walnut, but I think that would be hard to prevent it bleeding onto the surrounding wood.
Re: Ebonizer
Me neither.
I have ebonized lots of walnut but never before any machining. But if you decide to go with a good surface solution then I use black leather dye from Tandy.
Tom
Re: Ebonizer
Re: Ebonizer
Hi Galen,
The ebonized wood will be sandwiched between cherry and maple. The legs will be saw-tapered from 3-3/4" at the foot to 2-1/2" at the top over the 40" length (yes, top surface will be "low-bar" height). Trying to apply dye to the 1/4" elements after the tapering cuts will not fly as the dye will bleed into the adjacent wood, spoiling the piece. I'd hoped to dye the walnut then seal it to prevent any glue-leach. The Cherry I have gets pretty dark with age so there won't be sufficient contrast between the walnut and the cherry to "spark" the design.
Re: Ebonizer
Re: Ebonizer
Dick Coers
How about doing an inlay? Shallow 1/4" groove will let you use dyed veneer, or even ebony veneer.
Re: Ebonizer
Re: Ebonizer
Hi Dick,
Veneer won't be enough as this is for a kitchen and needs to have some meat behind the surface for dings, etm. Plus, since all four surfaces will be cut, I'd have to set up sever jigs to carry the tapered piece through the routing operation.
Think it's going to be way easier and faster to use 1/4x1 wenge strips and then use a filler strip that will be strong but hidden.
Re: Ebonizer
Clint Searl
Re: Ebonizer *LINK*
Clint Searl
How about black Delrin?
Clint
Delrin
Re: Ebonizer
Re: Ebonizer
Presents glue problems and I'd rather have an "all wood" construct, but the biggest issue is price. I'd need 1/4x24x48 sheet and that'll be $220+ shipping. Wenge's much cheaper.
