WE MOVED...
Particle board cabinet
Doug Ridley
I'm wanting to repair an old particle board cabinet for the church. The kind with the little screw thingies that just take a quarter turn to lock and it has been moved around a bit and the screw thingies have broken out the sides. Can I put it back together with quick drive screws and expect it to hold? I plan to replace the thin cardboard back with a full sheet of plywood which will fit perfectly and square it up good. Also do you think it is worth fooling with or should they go buy a new cabinet and trash this one?
Doug
Re: Particle board cabinet
Nat Robison
I think that type of cabinetry is crap. You could probably rehab it but could also build something way better with $50 worth of plywood in an afternoon.
Have the fittings worked loose because it's not screwed to a wall and is racking? If so, I'd just build new. If attached to a wall, you could get away with a rehab.
I put one of those knock-together in a bathroom before I got into woodworking and couldn't believe how bad those things are when I replaced it a few short years later.
Humble opinion . . .
steve mackay
VERY humble. I've tried "fixing" this stuff with screws. It never fails that, after a short time, the screws seem to "chew" up the material I screwed them into. Twice as fast if there were any stresses (ANY !) put upon it. At the wrong time IF I could get 'em in without chewing things up from the get-go. If it were mine (and I've done it many times) I'd pitch it before "sump'n BAD hap'n" to the wrong person.
George Colonel's Workshop-Havertown PA
Good Evening Doug,
I have to agree with the others. The partical board has no real structure of its own, and is naturally going to crumble with stress. Better to build one which will last.
George
Doug Ridley
I pretty much already had that opinion but wanted to see what others thought. So it is scrap. Thanks all.
Doug
Dave Bair, Eaton Rapids, MI
The plywood back will help. I've been able to salvage a couple of cabinets like this by adding a solid wood backer to the joint and screwing into the wood instead of the particle board. A little experimentation will tell you if it'll work.
